Steeper Exhaust angle bracket
shanet88
Post by shanet88 »
Has anybody on here used this manufactured bracket to create a steeper exhaust angle.
I am thinking of doing this but wondering if it is worth it. And is it too much work.
Would the link pipe bracket under the rider foot peg need cutting off do so?
Think bike! Think biker!
Re: Steeper Exhaust angle bracket
I did mine like that . Very easy to make two brackets . I made a set for ck yesterday .
And yes the front bracket needs removed
shanet88
Post by shanet88 »
Excellent cheers for that lloydie I will be hopefully making some brackets up very soon. What thickness plate have you used or would recommend? 3mm.
Veturinkuljettaja
Post by Veturinkuljettaja »
I have a pair of those brackets, covered in dust unfortunately. My Yoshimuras have welded linkpipes and I just couldn't line up the right-side exhaust correctly. If the linkpipes were connected with springs or clamps, it would allow me to twist the right-side muffler into correct position.
'99 Firestorm a.k.a.VETURI
Pearl Lively Orange
"Self-Rogered" forks with Racetech linear springs, Yoshimura RS3 SS, DJ Kit, Krieger CCT, SHINDENGEN FH020AA R/R, MRA Racing windcreen, Tapered steering head bearings, gl_s_r brass nuts :)
shanet88 wrote:Excellent cheers for that lloydie I will be hopefully making some brackets up very soon. What thickness plate have you used or would recommend? 3mm.
I used 3mm ali but stainless will be better
shanet88
Post by shanet88 »
Cheers for that. I was thinking stainless myself. Just trying to look for some scrap now at work. If not my father in law is a stainless sheet metal worker hopefully he will be able to get me some if I can't find any.
I'm hoping this works as my link pipes are clamped so hopefully these twist enough to get that sweet angle :)
Make me a better set today from s/s
gl_s_r
Post by gl_s_r »
You've got too much time on your hands...
gl_s_r wrote:You've got too much time on your hands...
Yep now I'm fitting a radial master cylinder :-)
nice one folks. i was just wondering how to get my pipes up a bit.. :clap:
fabiostar wrote:nice one folks. i was just wondering how to get my pipes up a bit.. :clap:
Viagra!!! :wink:
Viagra!!! :wink:
bout the only thing il get up these days :clap:
If it's any use, I'm making some quarter inch thick, cnc hangers next week. Designed to lift low level pipes up to a steeper angle and save some weight over the big oem hanger/footrests.
The only thing is, you'll loose the pillion footrests.
Let me know, I might make a batch of 5 or so.
Jamoi wrote:If it's any use, I'm making some quarter inch thick, cnc hangers next week. Designed to lift low level pipes up to a steeper angle and save some weight over the big oem hanger/footrests.
Sounds nice keep me informed :thumbup:
sounds nice indeedy, what sorta money are you talking?
