I am thinking of doing this but wondering if it is worth it. And is it too much work.
Would the link pipe bracket under the rider foot peg need cutting off do so?
![Image](http://img.tapatalk.com/d/14/02/03/agyha5as.jpg)
Think bike! Think biker!
I used 3mm ali but stainless will be bettershanet88 wrote:Excellent cheers for that lloydie I will be hopefully making some brackets up very soon. What thickness plate have you used or would recommend? 3mm.
Yep now I'm fitting a radial master cylinder :-)gl_s_r wrote:You've got too much time on your hands...
Viagra!!!fabiostar wrote:nice one folks. i was just wondering how to get my pipes up a bit..
bout the only thing il get up these daysKev L wrote:Viagra!!!fabiostar wrote:nice one folks. i was just wondering how to get my pipes up a bit..
Sounds nice keep me informedJamoi wrote:If it's any use, I'm making some quarter inch thick, cnc hangers next week. Designed to lift low level pipes up to a steeper angle and save some weight over the big oem hanger/footrests.
The only thing is, you'll loose the pillion footrests.
Let me know, I might make a batch of 5 or so.
