Dynojet Kit And Cans?
IgorVigor
Post by IgorVigor »
Hello.
I am thinking about getting some race cans and a dynojet kit.
I am unsure which cans to go for though...
I am looking at the Motad Venom Oval Stainless cans
and the Fuel Exhausts Oval Stainless cans...
Both are road legal (with baffle fitted) and are around £300 with link pipes delivered.
I had a Fuel exhaust on an old bike and was impressed with the quality, but I have heard that the Venoms are loud even with the baffle fitted (the fuel arent)
And that tempts me :)
Now is the dynojet kit worth the £90? :S
Seems a lot for a few jets, and needle with clips :S
And if I ran the cans without the baffles, I know most cans are similar then, so anyone care to say some base jet sizes, etc to start out.
Setup would be:
Motad Venom or Fuel Exhaust with no baffles.
Stock air filter
Stock engine
I know all bikes are slightly different but an idea of what jets I would need would be nice...
Main Jets are 175 and 178 so would something like a 190 be correct? (Standard honda jet sizes)
pilot screw 2 1/2 turns out (I would adjust them once all fitted)
What about the stock honda needles? add extra shims? or not needed?
any other jets need changing?
I know there are already posts about the dynojet kits, etc, but I am getting confused as one post will say one set of jets and another will say something different...
And I cant remember, but the standard carbs are Keihin VP's arent they?
I dont really want to spend out £50~£80 on a K&N or Pipercross filter...
I dont like the K&N's and I have read that the Pipercross are tricky to setup without a Dyno...
Thanks and await some help :)
P.S. Once they were all fitted and working I would see if I could afford to take it to GT Motorcycles in Plymouth as they have a Dyno and set up the jets etc as required...
IgorVigor
Re: Dynojet Kit And Cans?
Post by IgorVigor »
Just wanted to ask another question.
I need to balance my carbs, but I havent got the tool at the moment.
The rear carb opens to far, so it starts closing a bit past the fully open point, when the front carb is fully open.
which way will I need to turn the balancing adjuster to get the carbs open fully identically?
clockwise or anti-clockwise?
Thanks...
benny hedges
Post by benny hedges »
dont adjust the screw without gauges attached - there is no way of telling by eye & you'll probably make it worse.
as to the jets - id say yes, get the dynojet kit - try http://www.jcmotors.com in the usa, the part you want is e1185. find it then use the online chat thing to arrange cheap postage to uk as their standard rate is $39.
i ended up paying about £60 for mine.
the jets (as posted in another thread) aren't the same number as other manufacturer's sizes - check the other thread to see what the difference is.
i'm not sure you'd get away with just shimming the oem needles or if that'd give you a mega flat spot in the midrange.
as to the air filter, i wouldnt bother rejetting with the standard filter - you shouldnt have to, even with race cans..
if you are going to change the filter, i recommend the bmc1404R, but again it's an import!
why don't you like k&n filters?
IgorVigor
Post by IgorVigor »
I dont like cotton gauze filters personally...
They dont filter enough for my liking...
oil foam, like the pipercross are better...
personally, I would like an oil bath filter but I dont think the engine would like that :P
And I know I cant get the carbs perfectly balanced without gauges, but I can do it a little by ear, so I can tweak it so its closer to being open at the same time....
Just be aware the the cans go 2:1:2, so you can't use exhaust pulses on your hand to set carbs, like you can with a single pipe for each cylinder set-up.
IgorVigor
Post by IgorVigor »
I meant using the tube in the ear and listening for a difference when the tube is near the carb venturi...
