LED Indicator resistors
Does anyone know what the resistor rating is to get your led indis to flash correct. Going to try and get them through my work.
Re: LED Indicator resistors
im not sure but personally from experience would spend £20 and buy a motrax plug in and play relay . Used one myself and is so so easy!
Honda Britain 50th anniversary storm (26 of 50)
Carbon Hugger
Carbon undertray
Carbon LED indicators
Clear LED rear light
Shark Skinz Bellypan
Harris RearSets
Ohlins Steering Damper
Proflex suspension
Remus high level carbon cans/micron stubbys
Carbon Hugger
Carbon undertray
Harris RearSets
Proflex suspension
ah didn't realise there was such a thing cheers will do that
Other than that Hein Gericke do some nice little resistors on ali heatsinks- were about £3 each, probably gone up a nadge now.
EDITNo, still at £2.99 each!
http://www.hein-gericke.co.uk/shop/adva ... 9utuvm8r1r
Or for a cheap option, wire up a normal filament indicator bulb in parallel and leave it sitting under the seat- one each side.
That’s what I did on my VTR Tony
Just popped each bulb into a plastic film tub (back when camera's used films... ) and taped them up so they didn't inadvertently stick to anything under the seat or get cracked. Left plenty of spare wire on and pushed them out of harms way.
Sorted
Sorted
SP1's rock!
Like Bigrich, I didn't bother messing about either and just fitted a Motrax flasher relay for LED's like this one:-
http://cgi.ebay.co.uk/MOTRAX-FLASH-LED- ... 2a0557bf74
I see there are cheaper flasher relays available, but don't know how good they are:-
http://cgi.ebay.co.uk/MOTORCYCLE-LED-IN ... 519028d274
