Idle Speed and Choke
davebonline
Post by davebonline »
Got a couple of questions: firstly, what sort of revs should my Storm idle at, and is it OK to adjust this to help prevent stalling?
Secondly, I have to manually hold my choke on to start my bike, if I let go the choke switch thing retracts all the way back - shouldn't this stay in position?
thanks
Sent from my MotoG3 using Tapatalk
Re: Idle Speed and Choke
1200 –1300rpm. While it wil happily idle lower have it slightly up a bit to keep it from stalling from carb farts in slow speed turns.
And tighten the choke adjuster where it mounts to stiffen the movement.
Wicky wrote:1200 –1300rpm. While it wil happily idle lower have it slightly up a bit to keep it from stalling from carb farts in slow speed turns.
Unless the nut is split...Behind the choke plunger is a rubber boot. Pull this back & you will see a knurled plastic knob, trurn it to tighten up & it should make the plunger stay out...but they can split so it wont work as should. You can try to repair with epoxy glue...Honda in their wisdom dont make this a part you can buy seperatly...IIRC you can get the the first part as a whole as it runs down to a splitter...
As a very cheap & temp mesure, use a clothes peg to keep it out.
Wicky wrote:Image
How much I need one of those !
:lol: :lol:
We could set up a cottage industry churning them out - Frank with his 8 arms could man a speedy production line meeting the demand!
macdee
Post by macdee »
MacV2 wrote:
Wicky wrote:Image
:lol: :lol:
i need one of these real bad :clap: :clap:
Roger Ditchfield
Post by Roger Ditchfield »
:lol: :lol: :lol: :lol: :lol:
davebonline
Thanks all, already sorted before replies, found the plastic screw cap behind the rubber boot.
So where's the idle speed screw on the VTR chaps?
Muchly :)
Other side of bike between the frame rails by the coolant bootle region. Ideally find a child with small asbestos hands to turn the idle knob. Oo eeer...
VTR1000F (Superhawk) Firestorm Service Manual PDF > http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=18025
baycat
Post by baycat »
Wicky wrote:Image
can I have one in orange
davebonline
Re: RE: Re: Idle Speed and Choke
Wicky wrote:Other side of bike between the frame rails by the coolant bootle region. Ideally find a child with small asbestos hands to turn the idle knob. Oo eeer...
Awesome, thanks :)
