Choke cable set, plastic intact, SOLD
Moderator: VTRDark
As heading.
Snapped yours?
These are good to go. You re-use the springs and tiny pistons/needles from your set.
wall.j
Re: Choke cable set, plastic intact, Sevenoaks, or Clapham £12 posted
Post by wall.j »
Hi Tony,
My choke that doesn't stay out drives me up the wall, might have this off you and fit it at Grainstorm, give me something to do!
wall.j wrote:Hi Tony,
Try tightening it up first...Under the choke plunger is a rubber hood, peel it back & you will see a knurled plastic nut, give it a tighten up this should help but they can crack which renders them useless...
wall.j
Post by wall.j »
Yeah, I've fiddled with it on many occasions, nothing I do seems to work... Guess for the sake of £12, could be an easy fix!
Sent from my SM-N910F using Tapatalk
wall.j
Post by wall.j »
Paid and added address as note on PayPal.
Thanks Tony.
