Top Tips
Top Tips
Anyone got any Top tips, anything Bike/storm related ?
I know this will get abused to hell but who cares
I lost one of my tank/frame rubber spacers the other day,
found it eventually and applied double sided tape to the inside
lip and now its stuck good !!
Re: Top Tips
1/ Use some grease on the wheel spacers to help keep them in place when re fitting your wheels.
2/ Never hit a bomb with a hammer.
Re: Top Tips
1) put a dab of silicon sealer on the top hat spacers at the front of the tank, stops them falling out as you carry the tank to that safe place where you wont drop anything on it!
2) always fill your bike up when it is being held vertical, filling up on the sidestand doesn't get enough in.
3) set the trip meter everytime you fill up and when you get to 90miles start looking out for a petrol station.
4) use the killswitch to get a great backfire when you ride past cyclists and people walking their dogs, they love it.
5) put a thin wipe of grease on one side of a new gasket before you fit it and it will always come off without ripping
6) try and make sure your tank is close to empty before doing any work that involves removing it.
- Miztaziggy
Re: Top Tips
Haha, I can attest to that. Dogs and cyclists do in fact love it. They love it most when it's totally unexpected, close range and deafening. I've seen cyclists wave 'more, more' and dogs jump up and pull their owners to the ground.AMCQ46 wrote:
- agentpineapple
Re: Top Tips
dollop of grease under the rubber boot on the starter motor.
also the rubber screen nuts can be used to secures several fixings on the rear fairing
- bazzashadow
Re: Top Tips
AMCQ46 wrote:1) put a dab of silicon sealer on the top hat spacers at the front of the tank, stops them falling out as you carry the tank to that safe place where you wont drop anything on it!
number 3
always do this or you get half a tank, but went in my local petrol station the other day and the girl inside shouted out the tannoy "get off your bike" when I didn`t she said "get off your bike for health and safety"
I got my helmet back on and went to a different garage.
h & s gone mad
Re: Top Tips
1, cut all your overflow pipes at an angle to stop them filling up with road crap.
2, fit a magnetic sump plug.
3, never txt while riding
Re: Top Tips
You'll be alright on a yellow one mate, plenty of time to text travelling at that speed!fabiostar wrote:1, cut all your overflow pipes at an angle to stop them filling up with road crap.
Re: Top Tips
Re getting off your bike to fill up,
I had a chap in the local Tesco's come out to tell me that this is now going to be mandatory, agreed it bolloxs but apparently its getting run out everywhere. Still let me fill up sat on bike whilst telling me this
Don't hassle me
I'll get there at some time
Re: Top Tips
ya blue whoreKev L wrote:You'll be alright on a yellow one mate, plenty of time to text travelling at that speed!fabiostar wrote:1, cut all your overflow pipes at an angle to stop them filling up with road crap.
- Pete.L
Re: Top Tips
I had the same. But I didn't handle the situation too well and told the spotty little oik of a shop manager what I thought of his stupiditygrumpyfrog wrote:Re getting off your bike to fill up,
Needles to say, there's another petrol station I can't go to
Re: Top Tips
Why not just put your bodyweight up against the bike to hold it up a bit while filling up. Obviously not totally upright as it may topple over but surly one can workout where the tipping point is without dropping the bike. Or put one hand on the bar and the other on the pump. This is going to become common practise in fuel stations now because of the increase of folk filling up and doing a runner. It's always the innocent that have to suffer the consequences.
Re: Top Tips
Fek 'em bloody jobs worths.
Pay at pump where I can saves having to go in to pay & queing up behind the twots doing a weekly bloody shop in a petrol station...
Re: Top Tips
I hate that, it really winds me up. It's like standing behind someone doing the lottery. They should have separate tills for these. Put some more people in employment too.weekly bloody shop in a petrol station...
Suppose I better add some tips.
Use the rear wheel spindle to knock out the swingarm spindle. They are both the same diameter but one is longer than the other.
Always loosen tight nuts and bolts before jacking the bike up, especially swingarm linkages and top suspension nut.
Loosen front sprocket nut before loosening chain.
Loosen choke cable at the frame and feed it through when removing carbs rather than undo the plastic nuts on the carb end.
