Nitron shock, belly pan, hugger
Moderator: VTRDark
StuartWags
Post by StuartWags »
Nitron shock £250 posted - almost new
Fiber glass pan Belly Pan with brackets £70 posted - cracked but repairable. Paint scuffed through in a few places
Hugger with bracket. £60 posted - Clean and ready to fit. Minor scuffing from tyre. Bracket could do with a paint.
Pick up from PE12 0TP is OK. PM me if you are interested
TravisZack
Re: Nitron shock, belly pan, hugger
Post by TravisZack »
Couple of questions on the shock... what spring does it have on and whats the eye-to-eye length?
ConTRo13R
Post by ConTRo13R »
Got any pics of the belly pan on a bike? In for first dibs ;)
StuartWags
TravisZack wrote:Couple of questions on the shock... what spring does it have on and whats the eye-to-eye length?
0700X225x0950 3711 it says on it. I will check the unloaded length. sits the same as standard when fitted
StuartWags
ConTRo13R wrote:Got any pics of the belly pan on a bike? In for first dibs ;)
the nitron shock is adjustable from length with the locknut on the bottom.
StuartWags
AMCQ46 wrote:the nitron shock is adjustable from length with the locknut on the bottom.
about 30mm on the seat height i hear but not checked
TravisZack
That's good to know. I'm just checking on the spring but I'm interested.
Stuart, did you buy it new and set for your weight?
StuartWags
it says this 0700X225x0950. guessing 225 is length of spring but not sure which is the stiffness though
StuartWags
no sorry
TravisZack
StuartWags wrote:it says this 0700X225x0950. guessing 225 is length of spring but not sure which is the stiffness though
Not to worry dude, I'm trying to find out from Nitron if it's suitable for my weight.
According to a spring weight calculator for the VTR I need something around an 1150lb/in spring. I'm assuming here the "0950" is the rate but we'll see :confused
TravisZack
Ok I was right about the 950 part and it being under sprung for me, but I can get it re-sprung so ummm... I'll send you a PM :thumbup:
The NTR R1 has 7mm of length adjustment according to Nitron.
