What's in a noise?
What's in a noise?
Hi All
So I'm new to V-Twins and still getting used to the thumping going on near my sensitive areas.
I've been riding it for a week or so now and it's certainly good fun, but I can't tell if it's running right or if I'm just imagining things.
More recently (after a run out last weds) it seems to sound like it's slapping a bit, that's the only way I can explain it! The noise from the exhaust is a bit more like a bang than a rumble and it seems to want to backfire and burble on the overrun.
Am I just being paranoid or is there somewhere I could start looking?
Re: What's in a noise?
If you sort out the cct on the bike most of the worries will leave you as far as the engines goes
Mcct or stopper mod for peace of mind
Thanks for the reply.
It's got manual CCTs already, not sure how to know when to adjust them. Just reading through the reams of information you guys have (seriously, I'm a member of lots of forums and not a one has the vast knowledge base this one does!)
Turn up to an event (Workshop day/ rideout) so somebody can listen to your Storm beastie for untoward noises that can be hard to describe in words.
The most common noises are 'carb fart' (perfectly normal), suck squash bang & blow, and the occaisonal CCT 'death rattle'. Banging on overrun usually a sign of fuel weakness/airleak in the exhaust /intake. Have you checked the header/link pipe gasket seal and manifold gasket for leaks? Carbs seated properly ? And if you have a more freer flowing aftermarket can this will be noiser than standard and might need rejetting/dynoing for optimum performance.
Wicky wrote:Turn up to an event (Workshop day/ rideout) so somebody can listen to your Storm beastie for untoward noises that can be hard to describe in words.
Cheers Wicky
I do plan to meet up as soon as I get chance. Even if it's just to listen to other bikes and see if mine's "normal"
That's given me some ideas of thing I need to have a look at. I'll check the exhaust and the carbs. It does seem like something might have rattle loose after a ride.
- TravisZack
I've had the same thing recently. It doesn't sound as deep and throaty as before, it's got a harsher kind of crack to the exhaust note. Also surging at 4k rpm, which I'm slowly trying to fix.
Was all good (I think) before removing PAIRS and fitting a quick shifter, so maybe I should refit PAIRS and disable the QS, see what happens.
Sounds like a plan, start from scratch and go from there.TravisZack wrote:I've had the same thing recently. It doesn't sound as deep and throaty as before, it's got a harsher kind of crack to the exhaust note. Also surging at 4k rpm, which I'm slowly trying to fix.
PAIRS, pain in butt rear shock?
PAIR is a Pulsed Air Injection, draws clean air from the air box through reed valves in to the exhaust post combustion which ignites any unburnt fuel, it's an emissions thing.. on a storm you can flip the reeds over remove hoses and blank off.
PAIRS only fitted to later Storms in the UK...What years your one ?popkat wrote:PAIR is a Pulsed Air Injection, draws clean air from the air box through reed valves in to the exhaust post combustion which ignites any unburnt fuel, it's an emissions thing.. on a storm you can flip the reeds over remove hoses and blank off.
Ah, mine's a 97 so not on the list of bits to worry about
Worth knowing, cheers. Mine's an 02. Haven't looked in that detail yet.popkat wrote:PAIR is a Pulsed Air Injection, draws clean air from the air box through reed valves in to the exhaust post combustion which ignites any unburnt fuel, it's an emissions thing.. on a storm you can flip the reeds over remove hoses and blank off.
I have an fmx650 motor which is nestling in a cb250rs frame. That came with hoses into extra ports under the exhaust ports. Must do a similar thing? They're getting blanked off.
