Phone charger
- Miztaziggy
Phone charger
I know some of you have these on your bikes, but I'm wondering where you connect the +ve to please?
I don't want it connected to the permanent live, just a switched live, preferably without stripping the bike down to find one?
Re: Phone charger
rear brake light +ve feed that is right beside the battery. is live with ignition
- Miztaziggy
Re: Phone charger
Great OK thanks, assume that's live even when lights not on?AMCQ46 wrote:rear brake light +ve feed that is right beside the battery. is live with ignition
Re: Phone charger
yes, one side of the switch is always live when key is on, other side is only live when the switch is closed
Re: Phone charger
Is there not a plug already on that ? Can't remember if I fitted one ,
- Miztaziggy
Re: Phone charger
Hmmm...I don't think so not that I can see anyway?
Re: Phone charger
I have these fitted to my bikes.
http://www.bikersoracle.com/vfr/forum/s ... light=loom
- Miztaziggy
Re: Phone charger
Mine is wired to my FZ1 fuse box.
I have it wired to two circuits, one hot all the time and one switched...wired to a dual pole switch. I leave the dual pole switch in the "Switched power" mode ..but have the key off mode available if I want to charge the phone, headset while parked.
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
Post event services
Total Rider
Phone charger
That loose plug above the negotiate on the battery is the one [THUMBS UP SIGN]
One wire going to the frame (earth) and one going into the loom (live brake light switch)
Re: Phone charger
you can get a matching plug from maplins that will allow you to connect any number of different accesories
