Dont forget the washers!!
mark2000vtr
Post by mark2000vtr »
Hi all.Just a warning that may have been covered before but I have learned it the hard way.After doing the manual cct mod make DOUBLE sure you put the washers back under the CAM COVER BOLTS. I missed one off the front and one off the back cover.Bike ran lovely,but was pissing oil out at these two point,s. Sod,s law dictates that the front one was the top right one (when sat on the bike) which is impossible to get at without tearing the bike back down to get at it as those who have done the mod will know.Replacement washers only £2.25 from wemoto though and I have put instant gasket on the underside of the washer,s too to make sure.All good practice though I suppose!!!! :oops:
Re: Dont forget the washers!!
hahaha been there mate, the washer stuck to a bolt in my case, and when I put it back together I ended up doubling up on one bolt and having no washer on the other....doh!!!!
luckily it was a rear, but still a right pita, it made one hell of a mess..... :lol: :lol: :lol:
Flatline
Post by Flatline »
I know what you've been through Mark :wink:
Done it too and it makes a good mess !!
mark2000vtr
Everything seem,s to be fine now though chaps have only run the bike up to temp in the garage for 20 mins with no leaks but hoping to take it for a shakedown on the road this weekend if it stay,s dry.Time will tell!!! :thumbup:
also remember to fit them the correct way up
darkember
Post by darkember »
Another point that can be missed is the small o ring on the dowel under the cam cover if that gets missed the same effect will happen
darkember
Post by darkember »
What puzzles me is how can you miss the large washer on the rocker bolts as there are 4 and if one is missing the bolt wont seat correctly
bigtwinthing
Post by bigtwinthing »
if you are not too familiar with stripping down etc, simply place all the bolts on an old tea towel or something similar and then at the end its very clear if you have forgotten something.
darkember
Post by darkember »
bigtwinthing wrote:if you are not too familiar with stripping down etc, simply place all the bolts on an old tea towel or something similar and then at the end its very clear if you have forgotten something.
:thumbup: i used a box and punched the bolts through it with the washers on :D
bigtwinthing
Yep that works too. i tend to lay something out and put all the tools on there too. i am organised though. :lol:
darkember
Post by darkember »
bigtwinthing wrote:Yep that works too. i tend to lay something out and put all the tools on there too. i am organised though. :lol:
Nah your just anal :lol: :lol:
bigtwinthing
lloydie hurt me bad :lol:
bigtwinthing wrote:lloydie hurt me bad :lol:
Least your still smiling [GRINNING FACE WITH SMILING EYES]
darkember wrote:Another point that can be missed is the small o ring on the dowel under the cam cover if that gets missed the same effect will happen
Dowel under the cam cover?
O ring?
Pics please, I can't recall ever seeing these.
The cam cover is located on the machined flat head mating surface with only the large rubber seal with four half moon sections moulded into it.
It's possible to have one of those misaligned, oil will leak out if so, but there's no dowel or O ring, iirc.
