petrol
bazzashadow
petrol
Post by bazzashadow »
this must of been done before :lol: but here goes
but what is best or does it not matter
98ron
95ron
shell v-power
I`m asking because were these bikes set up on 95ron
and if we put 98ron or shell v-power are we making them run wrong
Re: petrol
You'd never notice the difference! Its phycological :crazy:
Re: petrol
Unless you have fitted high compression pistons, skimmed the heads or run an ignition advancer it's a waste of time and money.
If you have made these changes it's essential....
ATM
Re: petrol
Post by ATM »
I have tried 98 with my track bike to see if I could notice any difference, but it seemed to perform the same so I stick with 95.
Cheers, Al
If you've over-cooked it, just lean it over more.
lumpyv
Re: petrol
Post by lumpyv »
I think mine does slightly more to the gallon with the good stuff but that may be all In my head :roll:
Re: petrol
As Tony says unless you have a modified engine there is no need for the good stuff. You're just wasting money. Put a drop of good stuff in now and again as it contains extra cleaning additives but don't expect the engine to perform any better or fuel to last longer unless you include Placebo Effect. Actually it will most likely run a little worse.
Salty Dog
Re: petrol
Post by Salty Dog »
I put Premium Unleaded in my Strom, its suggested here in Oz.
But.... one day, i didn't have any in the workshop and tipped some old Standard Petrol in, the bike went better than it ever had!!
Lifting the front wheel out of corners that it didn't normally do.... So stuffed if i know.
Might try some lawn mower fuel next ;)
Not sure what options you guys have for Petrol, we have 3 here;
E10 - Standard with 10% Ethanol
Unleaded
Premium Unleaded - Which mostly comes with the companies detergents mixed in it (Shell, BP, etc)
Apparently the best fuel here in Oz, is to find a Petrol Station that just sells pure Premium Unleaded, before its blended with detergent crap in it. Not many around and really, who knows what it is anyway.
3 out of 5 people are not the other 2.
Re: petrol
every third or forth tank i put 98 in mine just to clean it and treat the valve seats but iv never really noticed a difference the way it runs.
Furrybiker
Re: petrol
Post by Furrybiker »
Tried super unleaded in mine when I first got it as I wondered if it would make any difference, and it did!
It ran worse, but started a little easier. Never bothered again.
vtrjock
Re: petrol
Post by vtrjock »
In my experience it works in some engines but not in others.
Running super unleaded in RF900s I noticed a very slight improvement together with an increment improvement in mpg. Trouble was, the extra cost kind of cancelled it out. They are mental old engines though. 8O
I'll try it in the storm somewhen..
Virt
Re: petrol
Post by Virt »
I usually stick the BP ultimate stuff in on payday, then normal for the rest of the month. No difference in power and a very minor (usually like 1mpg) economy improvement, but I just do it for the cleaning additives.
Bananaman
Re: petrol
Post by Bananaman »
For my 2penn'orth I stick a capful of 99% acetone in every tank of normal cheapo, i also do this with my 2.8 td mitsi, I find they both run smoother with a bit more omph, seems to improve mpg as well :thumbup:
Mr Grumpy
Four wheels move the body,
Two wheels move the soul.
Re: petrol
The best way to look at this issue is that you want to run the lowest octane rating that allows proper engine operation.
I say this for a simple reason.
In order to raise the octane rating they use additives.
All good but it is not gasoline.
So with lower octane ratings, yes you get less additives but more gasoline per liter.
Gasoline not additives is what makes power.
So in reality lower octane fuel can make more power as there is more of what burns and less additives to control the burn per set volume. :thumbup:
rmh
Re: petrol
Post by rmh »
I found no difference in the VTR but the KTM950 Supermoto spits proper good flames out of the exhaust on Super unleaded !!!
The KTM does have all the emissions and limiters removed but is a carb fed v-twin so quite similar so I`m surprised at the difference....
Guessing there is just less limiting the fuel going in when snapping the throttle closed and therefore burning in the exhaust ?
Rob
Rob Hunter
VTR1000 '99 / BMW S1000XR - 2016
Re: petrol
i did try a gallon of avgas in the storm once that a mate uses in an old race bike... it did kinda perk it up a bit but the first time i was out in the dark when you shut it of at high revs say comming up the a roundabout i got a lovely nice 2ft flame outa each can :clap: :clap: :clap: :clap:
