battery birdnest.
Diabolus
battery birdnest.
Post by Diabolus »
I have extra feeds coming off my motto batt 4 pole battery I want a switched 12v version of this http://www.ebay.co.uk/itm/Click-CT101C- ... 3f2e66e3d5 if poss or does someone have a better idea.
the extra feeds are for
  • volt meter
  • heated gloves
  • 12v socket
http://lincsrideouts.co.uk
Diabolus
Re: battery birdnest.
Post by Diabolus »
going to upgrade my volt meter to this aswell http://www.ebay.co.uk/itm/Click-CT101C- ... 3f2e66e3d5 :idea:
Diabolus
Post by Diabolus »
might use one of these http://www.ebay.co.uk/itm/On-Off-Round- ... 3cd9a160bf
any Ideas please as to a better set up as i think im experiencing some drain from the battery as the aux feeds are not switched. :think:
macdee
Post by macdee »
All a bit more than £3.50...
http://www.vtr1000.org/phpBB3/viewtopic ... 8&p=364858
I've got the eagerbeaver fused relay kit.
The Led one looks good for the money in Macdee's links.
Have got a larger amperage battery to cope with the added electrics.
Diabolus
Post by Diabolus »
yea I'm kinda thinking less than a tenner in all. lol
10robbo
Post by 10robbo »
hi chris
as you know ive got the same volt meter as you
just wire it to the ignition switch and there is no drain when bike not in use
easy really can get to where you need to be by just removing the clocks
Diabolus
Post by Diabolus »
yea, I wanted it straight off the battery as it gives a more accurate reading of what charge is being put into it. I. just want to tidy it all up abit and thought there might be some sort of 12v distribution box available that doesn't cost a fortune.
macdee
Post by macdee »
so whats wrong with the basic version then hay
http://www.vehicle-wiring-products.eu/p ... d-fuse-box
Diabolus
Post by Diabolus »
macdee wrote:so whats wrong with the basic version then hay
not sure exactly how that would wire in to how I want it. great site that has anyone tried there regulator/rectifier ? http://www.vehicle-wiring-products.eu/p ... -regulator
