Anyone in Norfolk area that can help?
Seriously banging my bloody head against the wall in frustration.
No seriously, I actually headbutted the wall
Ever since doing the CCT's my bike wont run properly.
Gutless, has a weird kinda 'chuggy' feeling and just backfires like crazy. Also its impossible to ride at low revs, it just wants to cut out all the time which makes it exceedingly dangerous to ride (if your stupid enough to try...)
Carbs are fine, hoses are fine, fresh fuel in tank - all the usual stuff is OK.
And as far as I can see the timing is OK.
I'll admit I'm not really too clued up when it comes to engines.
Just wondering if theres anyone in Norfolk area could come take a peek?
Re: Anyone in Norfolk area that can help?
whats your nearest town ,
im near kings lynn
im near kings lynn
I'm north/west of norwich.
I'm just a couple of miles off the Easton/Norfolk Showground roundabout on the A47
quite a distance off then,and I don't travel to anywhere in your direction.
I just thought it might be good to share thoughts etc I fitted mccts on mine last year and it all went good.
if its not the timing then most likely candidate is the vacuum pipe on the tank in wrong position. this one catches people out all the time
No worries matey.
Yeah I had a play around with the pipes and i'm 100% sure they are right as I photo'd the pipes before I took them off as I have a memory of a goldfish so I can say with relative certainty that it's not that.
I was wondering the same as Robbo. Just to clarify, the vacuum take off pipe that runs from the rear cylinder to the petrol tap (this applies to the earlier models, 16ltr fuel tank) should be fitted to the spout that sticks out the side of the petrol tap (horizontal), not the drain-off spout that faces down to the road (vertical),
It's easy to line up the wrong timing mark which can put the timing out by 1 tooth but the bike would still run and feel mostly ok. I agree with the others that you've put the vacuum hose on the wrong pipe, a disconnected vacuum hose would give the symptoms you have.
- agentpineapple
what about the hoses from the carbs, they have that right angle bend in them, it's easy for them to pinch and restrict flow?
Also check clips are tight on carb mount rubbers
- bazzashadow
I'm in Norwich but am not that good with engines either
Mine plays up as well but not that bad.
I once rooted the fuel pipe in the wrong way and that caused a miss fire and then a cut out
When I checked it all the pipes filled with fuel and then bike started ok but then started playing up again after about 100mts
But it does sound like this or timing seeing as that is what you have done
- thunderbolt
Did you remove the front cam cover when you fitted the manual cam chain tensioners?
Don
Bikes:
1981 Moto Guzzi 850 T4
1990 Suzuki VX800
2003 Honda Firestorm VTR1000
Don
Bikes:
1990 Suzuki VX800
AAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHsirch345 wrote:I was wondering the same as Robbo. Just to clarify, the vacuum take off pipe that runs from the rear cylinder to the petrol tap (this applies to the earlier models, 16ltr fuel tank) should be fitted to the spout that sticks out the side of the petrol tap (horizontal), not the drain-off spout that faces down to the road (vertical),
I think you might have cracked it.
I'll give that a whirl and see if it fixes my issues
thunderbolt wrote:Did you remove the front cam cover when you fitted the manual cam chain tensioners?
yup.
I did the valve clearances at the same time so everything was taken apart.
Me love you long time.
Runs like a sewing machine now
Mrs aint happy though, spent all morning on the bike
One slightly alarming thing though, when starting or giving the throttle a blip from low lidle there's a kind of metalic 'slap' noise... Well thats the best I can describe it. It's not quite a 'knock'.
But when its running it runs sweet as a nut.
Balance your carbsRichy85 wrote:Me love you long time.
