Help guys
Mickydjpjs
Help guys
Post by Mickydjpjs »
Hi all been out on my storm today about 200 miles..when i got home battery was smoking, disconected and removed it.. I,m guessing the rec,reg is shot and putting too much charge to the battery? ...iv,e ordered a new one to fit, and was just wondering has anyone else had this happen? ...the rec,reg was the original and iv,e read on here that they don,t last long....bike has 20 k on it...ive ordered the finned type...could there be another cause ???? Please help cos i dont want to miss any riding time...thanks mick
macdee
Re: Help guys
Post by macdee »
r/r is probably the cause the fined type is better
some men have fitted R1 r/r which are mosfet and said to out last the others
Mickydjpjs
Re: Help guys
Thanks for the reply mate..do you think my battery will be shot also?
macdee
Re: Help guys
Post by macdee »
if you can get the smoke back in it should be ok :lol:
chances are its buggered but fit the new finned type and see if it works
look up the workshop and check out the yamaha R1 R/R mosfet bit of work but its the best upgrade
Re: Help guys
I'd bin the battery and the r/r
Mickydjpjs
Re: Help guys
Thanks yep checked it out and looks good but i just need one to plug straight in, dont think i,m up to wiring things, if this new one lasts 20 k i,l be a happy man
macdee
Re: Help guys
Post by macdee »
Mickydjpjs wrote:Thanks yep checked it out and looks good but i just need one to plug straight in, dont think i,m up to wiring things, if this new one lasts 20 k i,l be a happy man
is it a Honda or a patented r/r
theirs some Chinese finned out there and i'm not sure how good they are
Re: Help guys
It's likely that the R/R has overcharged and boiled the battery. You will need to replace both as the battery is likely to have damaged cells. If you use a bad battery with a good R/R it will kill the new R/R or vica verca. Don't get caught in that trap of going around in circles so change both.
Rgulator Rectifier Charging System Diagnosis Checks
Beware not all R1 R/R's are of the Mosfet type.
More info here.
Mickydjpjs
Re: Help guys
Thanks for that lads ,iv,e ordered a new battery also
10robbo
Re: Help guys
Post by 10robbo »
whatever you do,dont buy one of the Chinese ones as a replacement they are worse than the stock Honda ones,it will go on you within weeks,ruining your new battery.
Re: Help guys
macdee wrote:if you can get the smoke back in it should be ok :lol:
:lol: :lol:
I went for a oem Honda cg125 finned reg/rec, £20 & 5 mins to fit.
But Mofset is the best option if you are prepared to do a little fiddling.
