just how do you fit an endless chain?
Now this might seem a bit dumb.........but never fitted one.
So is it easy?
are there any special tools required?
What size?
How many links? (standard sprokets)
So is it easy?
What size?
You will have to...
On other bikes to fit endless chain normally you need to take off swingarm. To be honest - can be pain in tha a...e job if you do not have good device to support bike.
But I had a look at my Storm and looks like on Storm you might get away by taking of left peg hanger, left lower can hanger, sprocket cover and (might be needed) front sprocket.
If that's the case you do not need anything more special than alien keys, big box key for front sprocket nut and patienence
Well, apart from one thing I always recommend to have, no matter what - torque wrench, so that you do not need to think to much how tight should be all those nuts and bolts....
- STEVESTORM
easy peasy
Previous description spot on. 102 link standard - 104 for my 15/45 t set up. I fitted an endless chain exactly as previous comments and got the old one off the same way. 1 rear axle stand £ 40 is recommended
Re: You will have to...
Bluesman, totally agree, torque wrench is a good idea regardless of what bike you've got. I have just one question: How do you know what the torque settings are for each nut?bluesman wrote:
- STEVESTORM
exactly, plus...
I do have Haynes, and also (if you do not want to spend 18 quid) - somewhere in forum I saw link to place where from you can download 100 mb PDF format workshop manual for Storm.
I did it, and it is indeed very nice manual, with ALL torque settings.
- STEVESTORM
