I have a bloody great split in my diaphram, (good job its not the wife's)
Can I still use bike without it?? or will it leak fuel all over the place ??
HELP !!!!!!
Geoff M
Can I get rid of diaphram in fuel tap ?
- smokin joes
- Contact:
Sex is like air. It only becomes really important when you aren't getting any.
I rekon the diaphram is there to shut off the tap when the bike is not running, right?
So why removing the rubber would be any different than having an old style tap (with ON, OFF and RES) and leaving it all the time on ON (like we all did anyway...)?
Is there something I'm missing here?
I'm not tailgating... I'm drafting!
- smokin joes
- Contact:
Removed offending diaphram, replaced with 50p "0" ring, re-assembled. Joined the two "spigots" at rear of tap with 2" of hose, (one is vacumn in, the other is breather)
Lo and behold.........it leaks...cos I forgot to put the "other half" of the diaphram back inbetween the two halves of the tap.
Re-fit again...lo and behold, no leaks.
Fully cured the problem of misfire as well !!!
I love it when a plan comes together,
and yes, it is only a "safety" cut out for the fuel.
Geoff M
Before you decide you dislike someone, try walking a mile in their shoes.
Then if you do decide you dislike them, you are a mile away with a free pair of shoes !!!
Geoff M
