Hi. Sorry for opening a new topic for this, but...
It is time to get the bike out of the winter sleep
And I am going to install the Dynojet kit I bought last year, but the "slide drill jig" was missiing in the kit (the drill was in the kit).
Please, can anyone help me with the position of auxiliary lift hole?
Thanks.
Dynojet - slide drill jig.
- Pete.L
H Petrolhead.
If you look at the slide from the bottom.(needle pointing toward you). You will see two stock lift holes already drilled. they will be in the bottom left and right cornerns of the slide. The hole you want to drill will be in the top right corner as if you were making a triangle. I did mine by hand with out a jig (there wasn't one in my kit either) and it has'nt caused a problem. Don,t forget to remove the needle retainer before you start drilling.Go Carefull. Good luck
If you want a pic Log on to http://www.dynojet.com.
It,s the U.S version but you can get pdf versions of the instuctions with pics
