Sensible tuning mods
So, you've seen my race bike in the gallery and I'm assuming that it's going to be quick and that it's had some engine work done. ASSUMING, you never know when you buy unless you pull it apart.
I've had the air filter box off and the filter has been removed, common?
It's running scorpion straight through race cans, loud and probably liberating a few extra horses.
What are the general mods done to Storms? I don't want a balls out race bike, just a quicker, more fun to ride, reasonably competetive race bike.
So, let the flood commence!!
Bikes and scorned women don't mix!
moriwaki pistons £600 ish
moriwaki cams £500-£600 ish
porting/gasflow £700 ish
dynamic balance £200
moriwaki carbs £1000
all of the above are just basic prices, so no labour or engine building/stripping.
or I could sell you a moriwaki engine, needs a strip and the shells checking but as it is, with moriwaki carbs for £1200, add £530 (£200 of which is labour) for a strip and rebuild and another £200 if you want it dynamically balanced.
Engine has done a total of 20k and the moriwaki conversion was done at 4,000 miles. it has moriwaki pistons, moriwaki cams, ported/gasflowed heads, vented crank cases, moriwaki carbs, moriwaki billet trumpets and a modified airbox. was dynoed in PB at 125rwhp as is - engine was from the anniversay one they did a write up on.
Del.
Del.
- blackstorm
This for the Moriwaki engine. Sounds great but out of my reach at the moment. The whole bike was only £1800, so £2k for an engine seems a little extravagant.
This is for the sprocket. Haven't actually checked teeth yet, pretty obvious really, so I'm going out to the garage now.
Cheers all
Cheers all
It's a revolution engine so as per a normal VTR, I would just suggest carb balancing often (every 2k) good oil (R4T) and change it when you should and don't rev it to the redline all d time. I have not heard of one letting go through an engine problems. Normally problems are due to neglect in the maintenance department i.e. cheap oil, riding with out of balance carbs all the time, over reving and down shifting too early. I have only done 3,5k on my engine and the rev limiter is set at 9,600rpm and I rev it to that all the time. did 100 miles at Brands last year in 5 sessions and bounced it off the limiter the whole day.
Del.
Del.
- firestorm996
- Contact:
- EggShellBlond
Hiya '996
I've got that article somewhere , I'll see if I can dig it out for you.
Robin, is that the Dave from K-Tech ? Looks like one of their stickers , but cant tell.
How does the Go Star thing work ? I had a look on their site , and it said something about helping with sponsorship , so if that's the case could you get help from them to stick the Moriwaki engine in ?
Be nice to see a VTR stuffing other bikes on a regular basis
Stu
Stu
If a job's worth doing..........It's worth paying someone to do it properly
It's Dave Parkinson from Race Componenets in Southport, he's been involved with BSB and the like over the years.
GoStar is a not for profit team that gets sponsorship for all it's members, usually small percentages from large companies, so not much hope for the Moriwaki there.
I gave "The Beast" a run out at Brands on Wednesday and I was pleasantly surprised with it's performance. Went out in the inter group and stayed out front all day. It looks good for the season!
- EggShellBlond
f/s996 , did it arrive OK ?
Robin , what was the bike sold as ? ie trackday with new plastic , or a Racebike with loads of kit / receipts etc?
Had it ever raced before ?
Just being nosey , hope you do well on it, and have fun.
PS I had a look at the DP site , but couldn't see a " Twins " class , do they run with something else ?
Stu
Stu
Sold as a race bike. It was raced with DP last season and was third in the series.
There is a twins class, it runs in with the 750 class.
The bike is basically what it is, a Firestorm, which will always be a road bike on the track. It would take a fair bit of cash to make it very competitive against SP1's, 2's, Dukes and Milles, but I'm certain I can put in some good performances and make it look good!! (Modest, don't you think?)
