x ring or o ring?
Flatline
x ring or o ring?
Post by Flatline »
Nice to see plenty of vtr fans. had a look but cant find reference to which chain to buy.
Putting the old girl back on the road after a 4 years lay off!!!!!!!!!!!!!!!!!!!!!!!!!
its a standard 's' plate with 9k on the clock and now needs a new chain and sprocket set.
Going to put one tooth less on the front with standard on rear and need a chain but cant find out if i should use x ring or o ring. Your advice would be welcome.
Flatline
Re: x ring or o ring?
Post by Flatline »
thanks for that, what do you mean by more surface contact?
Is a X-Ring Type chain better than a “standard type” O-ring chain??? Much, much better because it’s seals are flat sided, which means the seals have a much greater “contact patch” with the Side Plates. Since the seals are flat, it allows for multiple “sealing lips”......each one acting like a separate seal. As one “Lip” starts to leak the lubrication the 2nd lip seals it in....& because X-Rings are flat shaped on the top & bottom too, this does’nt allow any room for dust & grit to get lodged between the seals. (See Picture!) A vast improvement over “standard type” outdated O-rings!!!! What all this means is, that X-ring type seals have less than half the friction of a O-ring type because the seals don’t have to be pressed as tight, so the seals last much longer & the lubrication stays in the chain much longer too... which means your chain can last almost twice as long.. (up to 30,000 miles)!!!!!!
http://www.quality-cycle.com/truth_abou ... chains.htm
Last month got an x-ring kit from M&P VTR1000F 97-05 Xtreme Ch/Sp kit £122.99 + 4.99 P&P
LutonStorm
Post by LutonStorm »
Hey Wicky,
was that £4.99 p&p from the USA or did you get it from the UK somewhere.
Think I need a set as the chain adjuster has run out of erm... adjustment!
Simon
UK from M&P
http://www.mandp.co.uk/productinfo/5021 ... pgrade-Kit
Buy it NOW Price £122.99
Suggested Price £150.00
Saving £27.00
Just make sure they send the rivet link with the kit! :mad2
Zakalwe
Post by Zakalwe »
If you are buying chains, then B+C Express are the place to go.incredibly helpful, really, really quick delivery, competitive prices and very friendly people.
Entia non sunt multiplicanda praeter necessitatem
stormingjoe
Post by stormingjoe »
Zakalwe wrote:If you are buying chains, then B+C Express are the place to go.incredibly helpful, really, really quick delivery, competitive prices and very friendly people.
agree there, have used them recently good prices and know whats what, also appear to be able to get ant size sprocket defo recommeded :thumbup:
Flatline
Post by Flatline »
This shop, DK Motorcycle spares are doing a DID kit for £79
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... TQ:GB:1123
thanks for all replies, much appreciated
Regards Flatline
snipper
Post by snipper »
i found these chaps cheap ( but good qualitiy ) https://www.bctmotorcycles.co.uk/index.jsp
