I think the hire company did me a favour now, the 900cc engine might be the perfect size for these type of roads on this island, where the 1200 V4 might have been too much of an animal. I have only found one road on a steep uphill climb where I didn’t have enough grunt to fire out of the turns as fast as I wanted (even if i was using 2nd gear ), but it makes up for that with Lower weight, better braking, agility and outstanding suspension.
The suspension is a revelation.
Yesterday we were on a particularly badly potholed road, i changed the mode from sports to touring so the suspension went from Hardest down 2 increments to Medium. While that was nice for absorbing the bumps and pootling about, as soon as we upped the pace it was diving on the brakes and you couldn’t be agressive, you needed to be smooth or the bike would get upset (as you would expect on a long suspension adventure bike). But back into sports mode and it was like a sports bike….. it is such a dramatic change to the dynamic capabilities with this suspension technology, it is like you have 2 or 3 different bikes available at the pres of a button. Way more functionality than my 10yr old KTM, I am impressed.
It can be more fun thrashing a smaller bike than using a bigger one to half of what it's capable of. Glad you're having fun.AMCQ46 wrote: ↑Tue May 14, 2024 8:34 am I think the hire company did me a favour now, the 900cc engine might be the perfect size for these type of roads on this island, where the 1200 V4 might have been too much of an animal. I have only found one road on a steep uphill climb where I didn’t have enough grunt to fire out of the turns as fast as I wanted (even if i was using 2nd gear ), but it makes up for that with Lower weight, better braking, agility and outstanding suspension.
Excellent newsAMCQ46 wrote: ↑Tue May 14, 2024 8:34 am I think the hire company did me a favour now, the 900cc engine might be the perfect size for these type of roads on this island, where the 1200 V4 might have been too much of an animal. I have only found one road on a steep uphill climb where I didn’t have enough grunt to fire out of the turns as fast as I wanted (even if i was using 2nd gear ), but it makes up for that with Lower weight, better braking, agility and outstanding suspension.
Glad you are happier with the V2 now
Chris
Glad to hear you’re getting on with the baby Ducati, it sounds spot on for your trip. My 1260s can be a bit of a handful at times, but I’m not very good at setting up the suspension.
I've had a pulsing vibration at wheel speed from the front discs for ages, so took my Brembo discs ( on the Aprilia) to Maidstone Motoliner a few weeks back to have them trued.
But I still had pulsing, so, today I cleaned the discs using fine emery and Scotchbrite pads, and I also cleaned the pad faces.
I checked the disc runout. Less than 2 thou, so good enough. This has sorted the problem.
It's odd, though- I've had lots of bikes with discs and this is the first time I've ever needed to clean the discs to get rid of vibration.
Still, all sorted now, and the calipers were also cleaned while I was in there getting dirty.
A quick ride to bed them in, and job's a good'un.
It's a good feeling when something as simple as that fixes a problemtony.mon wrote: ↑Wed May 15, 2024 4:24 pm I've had a pulsing vibration at wheel speed from the front discs for ages, so took my Brembo discs ( on the Aprilia) to Maidstone Motoliner a few weeks back to have them trued.
And it saves £500 for new discs.sirch345 wrote: ↑Wed May 15, 2024 8:09 pmIt's a good feeling when something as simple as that fixes a problemtony.mon wrote: ↑Wed May 15, 2024 4:24 pm I've had a pulsing vibration at wheel speed from the front discs for ages, so took my Brembo discs ( on the Aprilia) to Maidstone Motoliner a few weeks back to have them trued.
Now, what might I spend £500 (that the wife has already signed off) on?
Yesterday I had 3 hrs on the M1000RR BMW……. Sh1tting hell, that is an overkill bike. The seat, the suspension, everything is Just solid.. you don’t feel the traction, you just have to trust and push harder. It was a huge transition from the baby Ducati, and even the BMW owner wanted to keep the Ducati, as the BMW only made sense on perf3ct roads, and not all of the roads here are perfect (about 40% are, so better than home)
Today was a 370km day and some absolutely amazing roads, like nothing we have in the UK, its just continuous left then right then left for miles and miles, many are banked, but also many tighten up on you, so you have to be ready to lean harder. You go from sea level to 1000m then back down, then Back up. Mountain after mountain, it’s like black run skiing but uphill and downhill…. I would recommend anybody should try it. Flight £250, bike hire £750, apartment £450, it’s Better value than a ferry to Spain
tony.mon wrote: ↑Wed May 15, 2024 9:02 pmAnd it saves £500 for new discs.sirch345 wrote: ↑Wed May 15, 2024 8:09 pmIt's a good feeling when something as simple as that fixes a problemtony.mon wrote: ↑Wed May 15, 2024 4:24 pm I've had a pulsing vibration at wheel speed from the front discs for ages, so took my Brembo discs ( on the Aprilia) to Maidstone Motoliner a few weeks back to have them trued.
I like it,
Very interesting AlAMCQ46 wrote: ↑Wed May 15, 2024 9:33 pm Yesterday I had 3 hrs on the M1000RR BMW……. Sh1tting hell, that is an overkill bike. The seat, the suspension, everything is Just solid.. you don’t feel the traction, you just have to trust and push harder. It was a huge transition from the baby Ducati, and even the BMW owner wanted to keep the Ducati, as the BMW only made sense on perf3ct roads, and not all of the roads here are perfect (about 40% are, so better than home)
- freeridenick
Gave it a bit of a clean and fitted the captive wheel spacers I made.
Using some of your recently gained skills I see, great stuff Nickfreeridenick wrote: ↑Thu May 16, 2024 9:35 pm Gave it a bit of a clean and fitted the captive wheel spacers I made.
Very satisfying I would have thought, rather than purchasing them already made,
On my ZZR1400 it made it more comfortable when I fitted lower footrests and bar raisers, it is a compact fit for rider. I'm only 5' 8" and I found it tight. Helen on pillion has been saying she's been getting pain in hips. I bought these footrest off Mac recently so with a bit of modification and using some spacers off Hawk aircraft (I knew they would come in useful one day) fitted them. Hopefully she will be happy with an extra inch down there
redvtr
Tried out the Abba stand with front lift attachment that I bought this week.
It seems pretty stable, and although the strap device holding the rear down (on one side only) is a bit " Heath-Robinson" it works well enough. It'll make it easier to clean, having both wheels off the ground, without having to use two paddock stands.
Went out on the Triumph today and killed 23 million flies its now a black bike at the front i did find a nice quiet A road first thing this morning and that wee 675 has a better turn of speed than i would have though
