Bird Strike...
Close encounter with 'Columba livia forma urbana'...Thats feral pigeon in English.
Today I have mainly been turning this...
Into this...
Remarkably for a bike with 120k on it, used all year round, the top engine bolt came out with just a bit of hammer action & some plus gas... No grinders were use in the deconstruction...A large braker bar & the mains uggadugga gun did see some action...
Just a few bits to do to finish it off, remove the clutch case, the front head & the reduction gear.
You've been busy Mac :thumbup:
Ohh & the header studs/nuts came off as well without snapping... Theres someting to be said about covering your bike in oil & not cleaning it....Hahaha
MacV2 wrote: Fri Oct 14, 2022 8:54 pm Ohh & the header studs/nuts came off as well without snapping... Theres someting to be said about covering your bike in oil & not cleaning it....Hahaha
Really?
There's something to be said for the previous owner, Joe wasn't it :?: :clap: :clap:
Chris
Balanced the carbs then drained them as I won’t be using it again this year .
Noticed a fork seal is leaking so another job to do over winter .
I pi$$ed the entire street of today(again) running Dori up to temp :eek2 :eek2 :eek2 you would think by now they would be used to it :lol:
i did get a blip to the petrol station on the LC and peggy to fill them up. :clap:
Re: what have you done to your "bikes" today
Nue red got put away for winter, drained the tank, drained the carbs, fresh oil n fitter, cleaned, adjusted & splurged the chain with chain lube, coverd the exhaust spouts, slipped a cover over it. Roll on April...
Washed Hamburg, did the chain, checked the oil & tyre pressuers.
you know you are bored when you spend 20mins cleaning the chain :eek2 :eek2 20 mins il never get back 8O . .
in proper news i started to pull the clocks of the LC to fit mph inners..
fabiostar wrote:you know you are bored when you spend 20mins cleaning the chain :eek2 :eek2 20 mins il never get back 8O . .
Dilly Dilly Image
Sorted some bits out for the scrap man to pick up.
Sorted some bits out to sell.
Searched in vain for a BB stand I thought I had in stock... :x hamburg needs a lift up...
MacV2 wrote:Sorted some bits out for the scrap man to pick up.
Didn’t you sell the bb stand to someone recently Image
Duffy1964 wrote: Mon Oct 24, 2022 5:43 pm
Probably, but I had more than one in stock... Well I thought I did...Apparently not. :lol:
yellabell
Post by yellabell »
CBR600F4i calipers rebuilt. New seals, pistons etc ready for fitting. The CBR m/c is already on the bike waiting. On some of the shots you can see where the machining was done to aid clearance at the fork leg mounting points.
