tire rubber dust on swingarm chain and rear sprocket
Hi guys I got this problem since months maybe this is a good place to ask.
every time I clean the bike and oil the chain after a ride I found a LOT of tire rubber on the swing arm the sprocket and the chain. wha is ? why?
Does this rubber come from my rear tire or is it collected by the road ? sorry for the insane question but I'm going crazy, this thing never happen before on any of my bikes.
cheers
cheers
Re: tire rubber dust on swingarm chain and rear sprocket
What width rear tyre is fitted?
Have you checked the rear wheel bearings (inc sprocket carrier) and lastly, is a hugger (if you have one fitted) moving and touching the tyre?
it's a 180/55 Michelin road 4
All the bearings are ok (by touch) the are no signs on the tire of touching hugger or anything, rear tire is aligned and inflated correcly, I't doesn't seems to have odd wearing on it. I'm staring to think that this rubber is attracted by the chain oil from the road or something similar
sorry for my English
- Nosepicker
Maybe a daft question but are you sure that it's rubber?
I'm thinking that maybe the rubber dust is actually plastic from a worn down chain slider?
Best of luck, Martin
Bad choices make good stories
yes sure 100% it's tire rubberNosepicker wrote: ↑Mon Aug 30, 2021 12:33 pm Maybe a daft question but are you sure that it's rubber?
Ok, how about the noise dampening rubber from a front sprocket? Otherwise, rear wheel drive rubbers breaking down?
- freeridenick
Have you got a hugger fitted? If it's a tight fit the the tyre could be rubbing.
only the standard small mudguard near the shock, I'll try to remove it, maybe it could solve this strange thingfreeridenick wrote: ↑Tue Aug 31, 2021 10:26 am Have you got a hugger fitted? If it's a tight fit the the tyre could be rubbing.
Can you post some pictures?
An overly lubed, dirty chain can throw up crud that can look a little like bits of rubber.
No bike (yet).
- freeridenick
It won't be that then.tastethefloor wrote: ↑Tue Aug 31, 2021 10:32 amonly the standard small mudguard near the shock, I'll try to remove it, maybe it could solve this strange thingfreeridenick wrote: ↑Tue Aug 31, 2021 10:26 am Have you got a hugger fitted? If it's a tight fit the the tyre could be rubbing.
https://photos.app.goo.gl/2hj8iKQtZA3S3tHV7
this tiny rubber everywhere on the rear also inside the chainguard
- alanfjones1411
Could this be the 0 rings or X rings in the chain breaking up.Although I have never heard of this before ?
Good point, what do you use the clean the chain?alanfjones1411 wrote: ↑Tue Aug 31, 2021 3:45 pm Could this be the 0 rings or X rings in the chain breaking up.Although I have never heard of this before ?
Only Naftatony.mon wrote: ↑Tue Aug 31, 2021 3:55 pmGood point, what do you use the clean the chain?alanfjones1411 wrote: ↑Tue Aug 31, 2021 3:45 pm Could this be the 0 rings or X rings in the chain breaking up.Although I have never heard of this before ?
To be fair, if o-rings break up they don't crumb, they just split at one point and are thrown off leaving a rattly chain.
Have you had a chance to check the cush drive rubbers yet?
