https://vtr1000.org/phpBB3/viewtopic.ph ... 68#p154768
Interesting read, thanks Kev.Kev L wrote:This is what I was rattling on about, Beamish was the dude -
Have been on a few times just looking at threads without logging on but yeah, absolutely gutted the Storm has gone. It's another story for another time and the guy well and truly ripped me off - already spent a couple of hundred sorting out his cowboy tricks on the car I took, but ultimately, no fault but my own!sirch345 wrote:Hi Bleh, Good to see you back againsorry you had to let your VTR go.
I was only thinking about you recently, I was wondering if you remember who supplied your VTR rear undertray![]()
No problem Bleh, hardly surprising when you have so much on the go, plus Xmas around the corner. A shame about being ripped off, it's not nice when that happens.Bleh wrote:Have been on a few times just looking at threads without logging on but yeah, absolutely gutted the Storm has gone. It's another story for another time and the guy well and truly ripped me off - already spent a couple of hundred sorting out his cowboy tricks on the car I took, but ultimately, no fault but my own!sirch345 wrote:Hi Bleh, Good to see you back againsorry you had to let your VTR go.
The undertray was an ebay job pal and sprayed with colour match paint.
Sorry I missed this question previously, was taken away by the image (ooooh shiny), glad to see you're thinking of me though
You're more than welcome to use my photo's (of the broken CCT spring as below) in your MEng paper if they're any help, there's no need to reference my name to them, but rest assured those photo's are definitely mine.Bleh wrote:Thanks Sirch, all the images so far are fantastic.
I'm doing a brief study on the CCT's for an MEng paper which is why I would like images of the broken bits. They will all go towards my analysis section and justifying any areas redesigned.
If you wish to supply me your actual name (via pm), I can accurately reference the images should you wish me to do so?!
I'm finding this thread very interesting too, good to see what you have been doing with your drawings BlehBleh wrote:Thanks for the input Bazza. Wouldn't happen to have any images of any of the failed CCT's you've looked at by any chance?
This could ultimately become an extensive study but not enough time or enough resources (CCT's good and bad).
I've seen various designs today on my image viewing adventures and quite a few appear to have a fail safe built into the design. At least these manufacturers (or designers at least) acknowledge that there is an area of concern... 'le spring'!
The absolute ultimate ideology would be to get rid of CCT's altogether, I'm sure we'll all agree on that one. Honda VFR 400 system comes to mind (has the SP got the same?).
Liking this thread though, some lovely feedbacks coming.
It's interesting to hear your finds too Bazzabazza696 wrote:I have seen a few ccts both dead and alive, and there are few parameters to consider. We observed that there has been a lot of different finishes on the exterior of the main body and the inner machined surfaces, so you have to consider that they have come from different suppliers, therefore the same with the spring.
We have seen that on some of the springs there is a blueing on the outside of the spring and not on the inside, so we have concluded that there has been localised heat treatment, rather than complete heat treatment this could account for the way the spring has sheared.
From our observations the majority have failed as shown in sirch's picture and only few have failed as in wicky's.
A few have been corroded and failed, but because of the spring being rusty has caused it to jam in the body and saved the cct.
The best option would be Suzuki option of having it sprung with a ratchet mechanism to stop it retracting after spring failure.
Now that's very interested as well. I can't think of any obvious reason for this. Do they slacken at higher speeds or tighten?sirch345 wrote:It's interesting to hear your finds too BazzaI'm going to disagree though with the ratchet idea, unless one could be built with enough movement in it to allow for the different tensions required, as happens with the standard Honda CCT.
When I was putting time (too much I hasten to add) into R&D of coming up with the Stopper Mod, I found that both the front and rear standard CCT's do self adjust as the rev's rise and fall. So for a ratchet designed CCT to work on a Firestorm/Superhawk as the OEM does, it would need to accommodate that,
you could fit a softer end cap or a dampened end cap that would allow for some flex.sirch345 wrote:I'm finding this thread very interesting too, good to see what you have been doing with your drawings BlehBleh wrote:Thanks for the input Bazza. Wouldn't happen to have any images of any of the failed CCT's you've looked at by any chance?
Liking this thread though, some lovely feedbacks coming.![]()
Yes the SP1/2 has gear driven cams.
The best option would be Suzuki option of having it sprung with a ratchet mechanism to stop it retracting after spring failure.I'm going to disagree though with the ratchet idea, unless one could be built with enough movement in it to allow for the different tensions required, as happens with the standard Honda CCT.
From my findings the standard OEM front CCT slackens off approx 1/4 of a full turn as the rev's rise at approx 3,000rpms, then as the rev's come back down it re-tightens. The rear CCT however tightens up as the rev's increase, and slackens off again as they decrease.KermitLeFrog wrote:Now that's very interested as well. I can't think of any obvious reason for this. Do they slacken at higher speeds or tighten?sirch345 wrote:It's interesting to hear your finds too BazzaI'm going to disagree though with the ratchet idea, unless one could be built with enough movement in it to allow for the different tensions required, as happens with the standard Honda CCT.
I think you'll find most, if not all of the of the big four Japanese motorcycle manufacturers have had their share of CCT's failing over the years, it's not just Honda. No you're right they wouldn't admit to it. A petition was got up by the Superhawk forum years ago when the Superhawk/Firestorm was relatively new to the biking scene, it was probably only a few years old by then. IIRC some of the members from this forum also supported it, but it was dismissed by Honda.fabiostar wrote:This problem of CCTs is a long standing problem not for all the jap factories but Honda. history shows us that infact Honda are sh1t at making them, Early V4s, cb750/900s, VTRs, smaller VT and VT400/500s. it just seems to be a long ongoing problem for honda that they never really cured.or will admit to!!!
An inline four puts less strain on a CCT due to the configuration of a four cylinder, also if one does fail there's more chance of getting away without damaging valves. This is due to one cylinders valves being open and another being closed which equals out the pressure applied to the cam chain. As the Firestorm has two CCT's one for each cylinder, there can be no counter balance between the two cylinders, that's why there is more chance of valves getting bent compared to a multi-cylinder engine. I agree, the position of the front CCT has to have something to do with it, with it's lack of oil compared to the front one, although some rear CCT's have failed even though they are running in oil.mattycoops43 wrote:Can I bring a bit of (hopefully) clarity here.
I run a storm with manuals, I don't claim to be a storm expert, but I work in a garage with a business partner, and we build bikes together, now my partner has 30yrs service in honda workshops. I have tried arguing with him in the past, and to be frank he always ends up being right, it's bloody annoying.
We looked at this. Honda use the same CCT in quite a few bikes, including the cbr600 all through the 90s, that bike was NEVER known for cct failure. We do not think this is an issue with the tensioner.
The rear's on the storm are not prone to going. they sit at a totally different angle from the front one, and get more oil feed.
I'm not sure if that would work due to the nature of how the front and rear standard OEM CCT's operate (as I've described above) but you may know more on that idea than I do,bazza696 wrote:
