You should ideally do the cams before getting the carbs tuned in as these will affect the tuning, therefore you will be playing with carbs again once the cams are installed and clearances set. The carbs on these bike have got to be the most sensitive finicky carbs I have ever worked on. The smallest of changes elsewhere, especially cams/clearances will affect the tune.& will hopefully be fitting VTR cams in the new year too.
Have you adjusted the TPS at all yet? note that this will also go out of adjustment after changes in a carb sync and/or idle adjustment.
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=29429
