mirror extenders
mirror extenders
I have made mirror extenders, from aluminium bar. 50mm extensions, but coud be made any length. it bolts into the housing, using the existing bolt. then 1 additional bolt, to refit the mirror to the extender. i have tried them for a couple of months, no problems at all. improved vison. no drilling to mirrors, so can be removed at any time. just remove from bike for painting. a fellow forum member will post pictures.
not for everyone i'm sure. but for those interested an option.
i thought 50mm may be too much, but possibly 75mm would be ok. i will make a set & let you know how they are.
richard
richard
- VTRdH
- Location: Stiens, The Netherlands. VTR1000F BLUE THUNDER
- Contact:
Re: mirror extenders
here are the pics from bsabloke, including the coated version
Distributor KRIEGER manual cct's
VTR parts supplier worldwide
interested in a pair if your thinking of going into production and the price is rightbsabloke wrote:I have made mirror extenders, from aluminium bar. 50mm extensions, but coud be made any length. it bolts into the housing, using the existing bolt. then 1 additional bolt, to refit the mirror to the extender. i have tried them for a couple of months, no problems at all. improved vison. no drilling to mirrors, so can be removed at any time. just remove from bike for painting. a fellow forum member will post pictures.
richard
- benny hedges
they do look better than the usual chunky blocks under the mirror mount - well done
not putting mirrors on mine when it goes back together btw - im using a rear facing camera and lcd screen above the clocks
i have thought about this but what got me stumped was you need some way of reversing the image other wise when you look at the screen at the left you will be looking behind you to the right if that make sensebenny hedges wrote:they do look better than the usual chunky blocks under the mirror mount - well done
i may countersink the mirror arm. this will allow me to conceal the bolt head. i am a bit loathed to modify the mirror. i will check on the size of the head of the bolt required. it may look better done, especially when extenders are painted.
keep you updated.
i will check with the chap machining for me. may be able to make some sets for anybody interested. prices to follow.
richard
keep you updated.
richard
counter syncing the bolt would make them look even better .
well done
well done
I can supply these for £20 a pair + postage. no stock at the moment. Please bear with me if you are interested. i will re post when i have some made.
richard
richard
- denisblackvtr
Same for me aswell please.chric wrote:stick me down for a pair after xmas
GAS GRASS OR ASS NOBODY RIDES FREE
I will take some off you when you are up to speed please. Ta muchly.
They look the dogs danglies !
A pair for me please when ready. Thanks.
even tho i just bought a pair of blocks off of carl i'd be interested in a pair of these in black.......+2
