Hi
I have read on some forums that arround 40000 km its a good ide to get 2 new cam chain tensioner installedm becouse the old one get "tired"
Any one who can confirm this ?
Jens.
new cam chain tensioner ?
- bikerpiker
Re: new cam chain tensioner ?
Hi Jens ,
Yes i would say it is a good idea
Having said that ,there is a member of this forum who had done 100,000 miles before cam-chain tensioner (cct) failure ,but others have broke at only 2,000 miles.
There are various ways you could do this ,you could either....1/ fit new Honda cct's ,
2/ fit new Honda cct's with the stopper modification
3/ Convert your old Honda cct's into manual cct's,by fitting a bolt through them.
4/ Buy new 'Ape' manual cct's ,either from America or here in the uk. Poss a dealer in your country?
There are loads of threads on the forum about each of these options listed ,just do a search ,instructions to modify are all there
Stevie
Undo the middle bolt (big one/center one) stick a screwdriver into it and hold it there, now rev the bike, if the screw driver turns then your CCT is on its way out i was told at work.
its very expensive repair if you dont sort it!!
yes its an issue worth sorting!! and sooner rather than later!!
