Cleaned it up a bit, all in its had new rear disc and pads, new rear tyre, chain and sprockets, oil, filters, plugs, carbs balanced, shims checked, forks flushed fresh oil, head bearings suspension bearings regreased, stripped and cleaned the calipers, painted the wheels, fork lowers, bottom yoke, calipers. Manual CCTs and VFR clip ons. Removed the little guard from the link pipes ground off the mounting points and give them a brushed finish with wet and dry. Not in the pic new grips and I've put the original screen back on (the black one is cracked).
