great day out turned to sh1t
went out nice and early to get some miles under my belt b4 all the " colin mcgyver the sunday drivers" come out was doin well did 200 miles then had an eggy smell when i stopped in traffic..... thought it was the brakes as i had been larging it then 150miles laterit all goes pear shaped when the battery pops gel every where....... it seems that my reg/rec has gone up the swanie and boiled the battery... strange thing is that even thou its pumping out 19volts all the bulbs and ignition modules are un damaged good thing is i only had to wait for twenty mins for recovery(aa)
- yellafella
Strange you should say that. I've been having a problem with my Battery lately.
Optimiser says its fully charged but as soon as i go anywhere ( lights on, etc ) It wont start again. Bit of a pain bump starting it in a grassy field i'll tell you !
Anyway got home testerday and got the meter on it, showing over 14.5 volts charging. This seems a tad high ?
As soon as i stopped the engine the voltage dropped throughout the 12 volt range.
Removed the battery and put it on the optimiser which immediately started charging it. That was after a 25 mile run, surely it should have been fully charged ?
What do you guys reckon ? Battery buggered ? It is 8 years old ! Or Reg/Rec on its way out ?
Stu.
Stu.
![Image](http://i7.photobucket.com/albums/y290/kwakakid355/cooltext12229582.jpg)
IMO I would say the battery needs replacingyellafella wrote:Strange you should say that. I've been having a problem with my Battery lately.
Stu.
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
- Squiffythewombat
- Contact:
rec reg
well the good news is that a battery ( varta ytz12s bs gel pack type) is only 45 notes delivered the bad news is the honda upgraded reg/rec( as they have been having a few probs across there range of bikes) is a whooping 158.71, yes the r6 one will work but its no desgned for the out put of the honda alternator
David Silver do a genuine one for about £80 I dont know if its upgraded, try ringing them
http://www.davidsilverspares.co.uk/index.html
they also have cheaper ones
Max
![Image](http://i27.photobucket.com/albums/c156/wjames/babies2.jpg)
Re: rec reg
What about the R1 although I thought they were the same as the R6apexer wrote:well the good news is that a battery ( varta ytz12s bs gel pack type) is only 45 notes delivered the bad news is the honda upgraded reg/rec( as they have been having a few probs across there range of bikes) is a whooping 158.71, yes the r6 one will work but its no desgned for the out put of the honda alternator
