second gear keeps going into neutral on the upshift....
Hanuman
Post by Hanuman »
every now and again when i go to change up, it goes into neutral - to avoid this i'm having to be very heavy with the change.
also, how clunky should changes up be?
i'm worrying about nowt no doubt.
cheers
The Official Border Hooner.
2001 Storm.
2006 Hayabusa.
xxxrated
Post by xxxrated »
first to second is shocking, it is on all hondas that ive ridden. i find the best way to shift up with minimum hassle is to let the revs drop as low as possible before shifting up
alan
SECOND GEAR
Post by alan »
Its the same on all vtrs it has a very tall gear try changing up clutchless.
Fireman on a Storm
Post by Fireman on a Storm »
They all do that sir!!.
One tried and tested way of helping that I have found on both of my storms is to lower the height of the gear lever by about 1/2 to 3/4 of an inch. This gives you a more positive up lift of the gear lever when changing gear.
If you have not fiddled with the controls before, look at the rod that connects the lever to the gear box. Undo the lock nut at each end (one left hand thread and one right hand thread) then turn the rod in your fingers and the gear lever will raise or lower.
Another tip! Wear you normal riding boots when doing this so you can keep trying the lever out to get the perfect height.
cupasoop
Post by cupasoop »
I've never found a false neutral on mine, yours must be fecked. :wink:
Rich.
alan
neautral
Post by alan »
:lol: :lol:
JohnnyB
clunk
Post by JohnnyB »
Every honda I've had has done it to some extent.
Having your chain too loose doesn't help.
The best way I find is to change quite early into 2nd gear, make use of that huge torque, don't ride it like you would a in-line 4, you've nothing too gain by revving it hard in 1st and even less if you hit neutral :!: I think that I usually change up into 2nd at no more than 20mph, that way (as Cupasoop) I never hit a false neutral and it does away with that nasty crunch, hence less wear on the gearbox :!:
alan
gear change
Post by alan »
I agree Chris change up slightly early and its a lot smoother i only pull the clutch lever in a bit also, as fireman said if you fiddle with the linkage rod and raise it a little it helps as you dont have to pull it up as far.But saying that i have had gilles sets on for a couple of years now and they seem to have helped as there so adjustable.
Hanuman
Post by Hanuman »
phew. so it aint cattled then.
cheers
:P
2001 Storm.
2006 Hayabusa.
VTR1000KAZ wrote:yup... if ur going for it... it always hits bloody neutral !!!!!!
Have a read of my previous post Kaz in this topic :!:
Hanuman
Post by Hanuman »
well i dunno what it was but it stopped as soon as it begun - perhaps it was the Fully synth oil i put in... which has now burnt off and has been topped up with a litre of motul semi 10/40
2001 Storm.
2006 Hayabusa.
