Anyone use a yellow headlight cover on their bikes? Do these increase your visibility to car drivers? I know from driving my cage that sometime is it difficult to distinguish between car lights and a bike filtering down on the outside of slow moving traffic...
Headlight covers
Ayup. S'pose a headlight cover gives lens protection, too. (coming from
someone lucky enough to be following a Blade a bit too close, after the road was 'dressed' with chippings..)
Anyway, back to the story.. I use a yellow bulb in mine. Looks good- black
Strorm, yellow decals. Light output not really Storm's strong point anyway.
Bulb is 80/100W btw, so about same forward vision, only with a French look. Stands out from cars much much better. Cheap safety mod.
- VTRgirl
Hehehehehe... I've got one of these to put on the Storm. Just haven't quite worked out how yet. Gunna hafta modify the megaphone or something.
http://cogapa.com/
http://cogapa.com/
- VTRgirl
The one I've got has 60 sounds, including all the sirens, animals, music & all the old horn sounds as well as some phrases like "move away from the vehicle", "excuse me", etc, etc... BUT the big bonus is you can also record your own and the set-up also doubles as a megaphone.
I just wanted it so when I pull up next to yappy dogs in utes, I can bark back. But the most fun will probably be the sirens...
