2006 Petcock Kit
gavc
2006 Petcock Kit
Post by gavc »
Does anyone know if the 2005 petcock repair kit will work in the 2006 bike?
I am trying to find one to suit the later model bike with the pump attached to the frame, not the older style attached to the tank.
If it's available to order in Australia - even better...
Thanks
xeris
Re: 2006 Petcock Kit
Post by xeris »
What are you calling "the pump"? None of the models had a pump. Is it the petcock you are referring to?
Number 7 in the diagram?
https://www.cmsnl.com/honda-vtr1000f-fi ... 3ENwOTMK00
~ Mark Twain
gavc
Post by gavc »
Correct - specifically wondering if this will suit: https://www.ebay.com.au/itm/32382433355 ... name=11051
xeris
Post by xeris »
Maybe. The compatibility shows all years. That would suggest the the internals are the same even though the petcock is different. I'm guessing that your bike has the 19L tank, which was never used on the US imported bikes. I really don't know enough about the bigger tank to be of any help. I will advise that the aftermarket repair kits have been reported to be of questionable quality. I would only use OEM.
~ Mark Twain
