Hi from Reading
Re: Hi from Reading
Good work, well done :thumbup:
Commando77
Re: Hi from Reading
Post by Commando77 »
Nicely done. BTW where did you get your plugs from? I fitted a zx10 item and ive got to sort the connectors which are individually plugged in. Cheers.
purgeraptor
Re: Hi from Reading
Post by purgeraptor »
I got the plugs from eBay.
Lots for sale there, but previous seller is out of stock.
This seller does them
https://www.ebay.co.uk/itm/114387667580
Re: Hi from Reading
purgeraptor wrote: Wed Nov 23, 2022 10:28 am I got the plugs from eBay.
While we're on the subject, can you please point me in the right direction for the correct crimping pliers for these connection terminals :?:
purgeraptor
Re: Hi from Reading
I solder all my connections, so am not sure if these connector terminals can be crimped.
You do need a powerful soldering iron though, especially on the thick cabling I used.
Not eco-friendly, but use 0.5mm flux-cored solder with lead in it, not the lead free stuff. You can still get this from a few sellers on eBay, but they won't say lead for legal reasons, so usually advertised as Sn/Pb (tin/lead alloy).
purgeraptor
Re: Hi from Reading
Some people say soldering is unreliable, as it makes the cable brittle....but I've been soldering for over 40 years, and never had a single failure yet :D
You do have to do it properly:
Pre-tin the wires with solder
Hold the wire into the connector tail, and heat the connector and wire together until the applied solder flows well.
Don't use too much solder, and always apply the solder to the wire/connector and not directly onto the soldering iron tip.
Re: Hi from Reading
purgeraptor wrote: Fri Nov 25, 2022 10:45 am I solder all my connections, so am not sure if these connector terminals can be crimped.
Many thanks for your replies :thumbup:
I'm old school and prefer the lead type solder too over the non lead type.
After some head scratching I have now tracked down the crimping tool for these connectors, I knew someone had posted this info up, I just had to remember where: https://www.vtr1000.org/phpBB3/viewtopi ... 82#p351482
Photo taken from the above link:
purgeraptor wrote: Fri Nov 25, 2022 10:49 am Some people say soldering is unreliable, as it makes the cable brittle....but I've been soldering for over 40 years, and never had a single failure yet :D
Thanks also for the info on soldering,
purgeraptor
Re: Hi from Reading
Hi Chris, good find on the crimping tool.
I may try one next time, would certainly be easier!
Re: Hi from Reading
purgeraptor wrote: Sat Nov 26, 2022 5:43 am Hi Chris, good find on the crimping tool.
It was a photo from the Late Wicky, a great forum member who is very sadly missed,
purgeraptor
Re: Hi from Reading
sirch345 wrote: Sat Nov 26, 2022 9:42 pm It was a photo from the Late Wicky, a great forum member who is very sadly missed,
purgeraptor
Re: Hi from Reading
Few more jobs done.
Replaced the plugs, although they looked fine as they should be after only 9K miles.
Replaced the air filter....good that there was not a mouse nest in there, unlike what I found in my VFR!
Then fitted a pair of VFR 800 FI clip-ons to give about an inch rise.
Bit of a faff, juggling everything to get clearance to tank and fairing....but eventually sorted :thumbup:
purgeraptor
Re: Hi from Reading
A pic to show the difference in height.
Re: Hi from Reading
Hello and welcome . Your doing some good work there 👍.
Where did you get the plugs/connectors from for the reg/rec ?
Re: Hi from Reading
Looking good, well done 👍🏻
Re: Hi from Reading
The VFR bars look good, nice job 8)
