Hi from Reading
Re: Hi from Reading
Nice new nuts for those studs would set it off. Shame no-one makes stainless ones, at least, I've never seen any.
It's an odd thread, M7 from memory, but I don't know whether it's standard or metric fine pitch.
purgeraptor
Re: Hi from Reading
Post by purgeraptor »
tony.mon wrote: Thu Jan 05, 2023 11:21 am Nice new nuts for those studs would set it off. Shame no-one makes stainless ones, at least, I've never seen any.
Yep, it's M7. I thought about buying some new OEM nuts, but the price was ridiculous 8O
The old ones are a bit scabby, but useable.
Re: Hi from Reading
Google 90304 mm5 000
About a fiver each.
purgeraptor
Re: Hi from Reading
tony.mon wrote: Thu Jan 05, 2023 3:48 pm Google 90304 mm5 000
About a fiver each.
Cheers...comes to £23.26 with shipping for 4 from CMS.
So decided to check with Lings Honda...£18.75 with shipping!
Still a rip off, but you inspired me to finish the job off properly :thumbup:
Re: Hi from Reading
purgeraptor wrote: Fri Jan 06, 2023 9:19 am
About a fiver each.
:lol: I checked with David Silver £18.32 :wink: :lol:
purgeraptor
Re: Hi from Reading
sirch345 wrote: Fri Jan 06, 2023 8:34 pm
About a fiver each.
Can sense a new competition here :lol:
Re: Hi from Reading
purgeraptor wrote: Fri Jan 06, 2023 10:52 pm
:lol: :lol:
Re: Hi from Reading
Weigh them the price isn't important.....
purgeraptor
Re: Hi from Reading
Decided to fit manual CCTs after reading all the advice on the Board.
I'll be taking the cam covers off, as I want to check the valve clearances as well.
I've read that chain slack should be set to between 5 and 7mm (once the timing is set at TDC on compression stroke).
But also read that some people experience chain noise at this setting, and tighten the adjuster slightly further.
Should I go for the tighter 5mm setting?
Also do people use Loctite or liquid gasket (silicone sealant) at the base of the adjuster bolt where the lock nut tightens?
I've bought these, allegedly UK made :think:
Please shout if you've used them, and they're no good before I get stuck in! :lol:
Commando77
Re: Hi from Reading
Post by Commando77 »
I've got a pair made by a former board member, now with 14k on them. I couldnt detect any difference in sound quality even at 'quite loose' :( Nor did I notice any difference auto (with savers) to manual and I'm usually tuned in to noises, hence my third go at the mainshaft bearing over Christmas, dont ask :?
Commando77
Re: Hi from Reading
I forgot to answer your question. Yes, aim for 6mm without leaning on it, just a medium effort total pull up/down.
purgeraptor
Re: Hi from Reading
Commando77 wrote: Mon Jan 09, 2023 3:10 pm I forgot to answer your question. Yes, aim for 6mm without leaning on it, just a medium effort total pull up/down.
Cheers, that helps :thumbup:
purgeraptor
Re: Hi from Reading
Commando77 wrote: Mon Jan 09, 2023 3:07 pm I've got a pair made by a former board member, now with 14k on them. I couldnt detect any difference in sound quality even at 'quite loose' :( Nor did I notice any difference auto (with savers) to manual and I'm usually tuned in to noises, hence my third go at the mainshaft bearing over Christmas, dont ask :?
So what happened with the mainshaft bearing? :wink:
purgeraptor
Re: Hi from Reading
Into the gizzards :D
Apart from the manual CCTs, checking the valve shims and changing the carb pilot jets to #48, any other jobs I should be doing whilst this far in?
purgeraptor
Re: Hi from Reading
Oh, forgot to say the fuel tap flows fuel in the OFF position (which was an unpleasant surprise when I pulled a hose off the tank).
Bought a TourMax repair kit from eBay to hopefully fix it.
