Hi from Reading
zakisbak
Re: Hi from Reading
Post by zakisbak »
Could someone remind me of which VFR bars fit?
I thought it was just early VFR750 bars,40mm?
Re: Hi from Reading
The VTR fork legs (stanchions) are 41mm IIRC.
I think both VFR750 and VFR800 bars will work.
here's a link for you to read: viewtopic.php?p=409659
zakisbak
Re: Hi from Reading
Post by zakisbak »
Cheers mate
purgeraptor
Re: Hi from Reading
Post by purgeraptor »
Commando77 wrote: Sun Dec 11, 2022 3:38 pm Thanks. BTW that wasn't from Fleet/Crookham was it? Oct 2017 I looked at a 9000 mile example in blue with a funky alarm system that had to be switched each time it cranked. Can't be the same machine? :lol:
Bought it from a newish dealer in Farnborough...so could be the same one :think:
Hasn't done many miles in the last 5 years for sure.
purgeraptor
Re: Hi from Reading
sirch345 wrote: Thu Dec 15, 2022 8:55 pm The VTR fork legs (stanchions) are 41mm IIRC.
Yep, 41mm fit. Mine are VFR800FI bars.
The later VFR VTEC bars don't fit as they are 43mm
purgeraptor
Re: Hi from Reading
Split stainless exhaust clamps arrived...cheers Mac :thumbup:
Lots of Plusgas over a few days, then blow torch heat.....and the front nuts came off fine :D
Cut the old clamp off with a disk cutter.
Rear one is not too bad condition and hidden anyway, so I'll save that for later :lol:
Re: Hi from Reading
purgeraptor wrote: Sun Dec 18, 2022 2:33 pm Split stainless exhaust clamps arrived...cheers Mac :thumbup:
Well done in getting the flange nuts off without shearing any studs :clap:
Re: Hi from Reading
Good job getting them done . So many people don’t take the time and snap the studs .
purgeraptor
Re: Hi from Reading
lloydie wrote: Tue Dec 20, 2022 4:40 am Good job getting them done . So many people don’t take the time and snap the studs .
Cheers!
I saw your PM to me, but I can't reply by PM yet, as I don't have enough posts.
Anyway, yes go straight to battery from the RR with 12V and Ground. Put a 30A inline blade fuse in the 12V line...I use the maxi-blade type holder and fuse, as I've seen the strandard size blade fuse holders melt.
For the existing 12V / Ground bike connector that used to go to the old RR, just leave it taped up and tucked away.
No need to connect it to anything else.
Re: Hi from Reading
purgeraptor wrote: Wed Dec 28, 2022 4:33 pm
Cheers!
Thank you :beer: :beer:
Re: Hi from Reading
Don’t suppose you have a link to a decent maxi blade fuse holder do you 😁😉 please
purgeraptor
Re: Hi from Reading
Re: Hi from Reading
thankyou and ordered :thumbup:
purgeraptor
Re: Hi from Reading
You need to buy the 30A maxi blade fuse separately.
Plenty on Amazon though.
Re: Hi from Reading
purgeraptor wrote: Wed Jan 04, 2023 9:02 am You need to buy the 30A maxi blade fuse separately.
I have and a spare , very surprised just how much bigger the maxi fuses are ! They’re monsters 😳
