reg/rec
sammy347
reg/rec
Post by sammy347 »
i know you can put an r6 reg/rec on a storm can anyone tell me if a 2002 fazer 600 fits, tia
Re: reg/rec
sammy347 wrote: Fri Feb 18, 2022 12:16 pm i know you can put an r6 reg/rec on a storm can anyone tell me if a 2002 fazer 600 fits, tia
Check the part numbers, if they are the same then yes. If not then prob could be made to fit. Neither will be plug & play both will require some wiring to fit.
You'd need to check if it's a Mossfet type & if not then look for one of those instead.
sammy347
Re: reg/rec
Post by sammy347 »
cheers mac
Re: reg/rec
Sammy, some information from this link below that may help you:
viewtopic.php?f=18&t=18681&p=351482#p351482
northmanuk
Re: reg/rec
Post by northmanuk »
i bought a yam rectifier annd needed to join honda wires to a yam plug it was easy three yellow to the thre lower yam wires and the pos neg to the upper two plugs thejust use soldering and heatshrink wrap instructions came with the plug anyway i havent run the bike yet but its also got new generator
