Arm/sub assembly cushsion suspension
mjvw
Post by mjvw »
Needle Bearings 4 x no20 required £18.67 each
https://www.bike-parts-honda.com/honda- ... 00/2/11474
Found these Same Bearings ? 4 required at £6.87 per bearing;
https://shop.marksman-ind.com/ta1720z-- ... 1eccb38c26
Have any forum members used this supplier or even the same bearings? :thumbup:
Storming About :thumbup:
Re: Arm/sub assembly cushsion suspension
I get all my bearing/seal needs from a local bearing factors... Kent Bearings.
Anything they dont have on the shelf is orderd in & usally ready to pick up in a couple of days. :thumbup:
Far cheaper than Silvers/Fowlers & you dont get raped for the postage...
You do need to use them for the hardwhare bits tho... :thumbdown:
mjvw
Post by mjvw »
Cheers, will order from cheaper supplier. :D
