Custurd parts bike...
Moderator: VTRDark
Come & get me £500... Located North Kent.
80k on the motor...
Every panel has cracks & scuffs,
Tank dented. Tank is bare as removed sender & petcock.
No gear side footrest.
Bent rear brake lever.
Exhaust debaffed but scuffed.
No indis. Fronts smashed, rears only one survived. re used the only good one binned what was left of the rest...
No mirrors. left just the stalk left, right the glass cracked... binned.
No Mudgaurd. huge crack so binned.
Poss bent subframe.
No battery.
Crack to clutch cover, weeping oil. Temp fix with Araldite.
I was gonna fix it up & carry on using it but thought Fek It, not worth throwing any more money at it.
So I swapped a few bits off it with the one I put back on the road.
It will need tyres as the ones on it are dated 2014 so a bit old, front looses air.
Could be bear bones of a track hack...
There are some good bits... Callipers were refreshed earlier in the year. Shock linkage was swapped with a refreshed one in March. Had oil & fillter in March as well...
You do not have the required permissions to view the files attached to this post.
Re: Custurd parts bike...
As no one wants the whole thing I will be breaking this up in the coming weeks.
Still let the whole thing go as is for £500 or I'll start dismateling it as & when.
Drop us a line if your after anything before I anounce the breakage on FB.
As the origonal post says it lists all the damaged bits so read that first as it will save time if your after that bit which happens to be feked... :lol: :lol:
