Front brake calipers - rebuild?
bingo808
Post by bingo808 »
Hi
While I'm waiting on a set of drill bits to arrive to attack the fuel cap, I though I'd remove the front wheel to get a new front tyre for registration.
All went well, I used ratchet straps to lift the front wheel, thereby allowing me to remove the front axle.
BUT left front caliper is oily, as are pads. Rebuild or go 2nd hand calipers? I say rebuild both left and right, as bike has high kms.
Friend pointed out that pistons/bore could be pitted. So maybe I should disassemble caliper first to check condition?
Someone put it together, so I should be able to pull it apart.
Re: Front brake calipers - rebuild?
Full strip down. Clean the pistons & inspect if the corrosion isn't too deep you can dress them with a whetstone...
Oily ??? Its not the fork seal leaking is it ? That will be the only place oil can be comeing from at the front.
bingo808
Post by bingo808 »
MacV2 wrote: Fri Jul 16, 2021 6:18 am Full strip down. Clean the pistons & inspect if the corrosion isn't too deep you can dress them with a whetstone...
Correction. On 2nd glance it does not smell like brake fluid. I think it may be the fork seals. Best to replace both sideS?
bingo808 wrote: Fri Jul 16, 2021 7:04 am
Yep, no point in only doing one side... Chances are the other side will go a few weeks after you've done the bad one... Sod's law... Fresh oil wont hurt either, it's possible it's still the origional oil from the factory... Get new seals & dust seals & don't be tempted to buy cheap ones... Or you'll be doing it again after a few miles. Also worth looking at getting new bushes top & bottom.
Bottom bush... You'll need 2 of.
https://www.davidsilverspares.co.uk/par ... 415KCR003/
Top bush... You'll need 2 of.
https://www.davidsilverspares.co.uk/par ... 414KCR003/
Read this... viewtopic.php?f=31&t=29710
bingo808
Post by bingo808 »
MacV2 wrote: Fri Jul 16, 2021 8:30 am
Thanks for the guide link. After going through it, and talking to a mechanic mate of mine, I think I'll just remove the forks from the bike and take them to a shop for them to rebuild. I could do it myself, and it would be a great learning exercise, but I just don't have all the tools.
To remove the forks, just undo the handlebar pinch bolts and the triple clamp pinch bolts? Then slide fork out?
''To remove the forks, just undo the handlebar pinch bolts and the triple clamp pinch bolts? Then slide fork out?''
Obviously first thign is to surport the bike ! Do you have an ABBA stand ? Padock Stands ? Raffter's in the garage ?
First thing is remove the fairing & Mudgaurd then... Take a pic of the cable routing before you remove anything !
Crack all the nuts that need to be removed before lifting the bike...
But yeah once you have got the front end off the floor & the bike safely surported... It's gonna be like that unable to move for some days...
Your doing the calipers so drain them off first & remove them. Front wheel out, note the wheel spacers & which side they go on... Take the bars off, remember the wire clip thing top of the bar/fork & doing one fork at a time... Loosen the top pinch bolt. Then holding the fork with one hand loosen off the bottom yoke bolt... & the fork will slide out.
You forgot mudguard off.
tony.mon wrote: Fri Jul 16, 2021 2:18 pm You forgot mudguard off.
Happy now...?
bingo808
Post by bingo808 »
Actually, a mate of mine told me to give a small piece of plastic a go first - it's called "Sealmate"
It gets under the lip of the seal and removes any dirt etc. I think it's worth trying first.
I still need to clean up the caliper etc and get a new front tyre but can do that after.
MacV2 wrote: Fri Jul 16, 2021 2:57 pm
Happy now...?
Lovely, thanks for sorting that out.
bingo808 wrote: Fri Jul 16, 2021 10:21 pm Actually, a mate of mine told me to give a small piece of plastic a go first - it's called "Sealmate"
Depends on how bad the leak is... It might stop it for a while or compleatly... You have to ask how much oil has leaked out tho...?
