engine getting hot
mick007
engine getting hot
Post by mick007 »
finally got bike going.im in Australia and its quite hot .my engine got to about 3/4 on the guage(it's a 98 model)and the fan did not operate.coolant is new.any ideas ?
Re: engine getting hot
fan switch?
air lock
thermo stuck closed?
id be starting with those first of all :thumbup:
fabiostar wrote: Mon Feb 01, 2021 11:07 am fan switch?
air lock
Or the Fan Fuse. They have been known to blow for no apparent reason or if something stops the fan from rotating.
I have also seen someone incorrectly attach the ground wire to the frame instead of the radiator.......that one took a sec to find....lol
Also make sure the fan blades turn freely....there have been time when some debris gets stuck in the fan :thumbup:
Cadbury64
Post by Cadbury64 »
The fan should come on from about halfway on the gauge (corresponding to around 100C). As suggested above, check the fan blades turn freely, I had a stone jammed in mine and that caused the fuse to pop when it tried to run. The fan motor always has a live 12v feed, the thermoswitch connects up the earth path to make it run.
I havene't found my VTR to run hot at all (unless stuck in traffic) so if yours is getting hot while moving, there might be other issues like a jammed thermostat, faulty radiator cap or air in the system. If the hose to the expansion tank gets a hole in it, that will cause air to get sucked back in as the system cools down.
mick007
Post by mick007 »
thanks gents will check all those things
mick007
Post by mick007 »
cheers :thumbup:
