Led indicators
swild123
Led indicators
Post by swild123 »
Help please, I’ve brought some mini led indicators when I plug them in they work fine but flash to fast!! Any advice would be appreciated as I’ve got no idea where to star
Re: Led indicators
swild123 wrote: Sun Apr 28, 2019 6:26 pm Help please, I’ve brought some mini led indicators when I plug them in they work fine but flash to fast!! Any advice would be appreciated as I’ve got no idea where to star
You need to change the indicator relay... for a correct LED one... Loads on ebay...
swild123
Re: Led indicators
Post by swild123 »
Thanks is there a part number I need to quote? Or is it quite straight forward to find correct relay?
Re: Led indicators
swild123 wrote: Sun Apr 28, 2019 7:31 pm Thanks is there a part number I need to quote? Or is it quite straight forward to find correct relay?
No part number as it will be aftermarket...
You need a 3 pin conector to match the Storms plug...Later Hondas use a 4 pin Square plug...Storm one is flat/oblong. The LED one only uses 2 pins but may be sold as a 3 pin...
E-bay...J&S might have them...https://www.ebay.co.uk/sch/i.html?_from ... y&_sacat=0
swild123
Re: Led indicators
Post by swild123 »
Cheers I will check it out thanks for help
