Frame and engine wanted
Moderator: VTRDark
hawky
Post by hawky »
Frame and engine wanted for project build.
Will also require a tank and loom.
Please get in touch should you have anything suited.
Thanks
Re: Frame and engine wanted
So you got a pair of wheels cheaply?
:lol:
Wouldnt you be better off buying a cheap compleat bike, use what you want & sell the rest on...
StuartWags
Post by StuartWags »
i have a frame and V5, a dent free tank and a few other bits
hawky
Post by hawky »
I’m simply looking for the chassis and motor to build around and have a project keeping me busy for a year or so.
Will be fitting a radial front and different rear end and so on
StuartWags
StuartWags wrote: Wed Mar 06, 2019 6:41 am i have a frame and V5, a dent free tank and a few other bits
Up date
Swing arm with a deep score where chain was thrown but could be useful.
An engine that was a runner but the thrown chain broke the lugs of the chain cover but i would imagine in is
repairable. There has been some subsequent cannibalisation so the clutch cover has gone, the heads have no valves. Probably a few other odds and sods. The crankcase and gear box has not been disturbed
I have a loom but from memory the front and rear light plugs have been removed. So probably not an issues for a radical custom build
The frame has a small dent where lloydie missed the central engine mounting bolt while beating it with a hammer to remove it. Ok to fill if you are going with a painted frame
The tank is dent free and had the paint scraped off to prove it. Rust free
I would have to put in a lot of time to make some money out of this lot and personally i would rather have the space back.
If it is of any interest to you offer me a few quid and it could be yours. Located near Peterborough
StuartWags wrote: Wed Mar 06, 2019 7:47 pm
Up date
Thats nearly a bike....
A few bits and it's on the road in time for summer.
StuartWags
I don't need another project at the moment hence i would rather have the space
seems a shame to bin it
Red3446
Post by Red3446 »
Engines and other parts are available from Italy :wink: :
http://www.vtr1000.org/phpBB3/viewtopic ... fcb559777f
