Anyone fitted longer throttle cables
Flatline
Post by Flatline »
Having fitted higher bars, I would now like to fit slightly longer throttle cables, about 20-30mm
Has anyone done this?
Had some made up or used a set from another model bike?
jchesshyre
Re: Anyone fitted longer throttle cables
Post by jchesshyre »
Someone asked this on the facebook group a while back. I posted the following in reply:
CBR600F4 cable is 75 cm (inner) vs the Storm's 67 cm. Other years of CBR600 seem to be a similar length, some a little shorter than the F4 by a cm or two. 17910-MBW-D20.
If you wanted much longer, the 1990s ST1100 one is 102 cm. Part no 17910-MT3-000.
Flatline
Post by Flatline »
Thanks for that, I've just updated the question as I'm only looking for about 20 - 30mm
It's good info though :plainsmile
grumpyfrog
Post by grumpyfrog »
What sort of risers are you putting on Phil, never changed mine?
Don't hassle me
I'll get there at some time
Flatline
Post by Flatline »
I put vfr ones on a year or two back, just never got round to fitting longer cables. They're ok as they are, just a tad short on full lock, so it's rarely noticeable
Flatline wrote: Mon Feb 11, 2019 11:30 pm I put vfr ones on a year or two back, just never got round to fitting longer cables. They're ok as they are, just a tad short on full lock, so it's rarely noticeable
You still routing them round the front of the forks ? Try changing to run behind the fork...
Flatline
Post by Flatline »
:thumbup: will look at that Mac
Flatty, take the return cable off and route the cable outside the fork leg so it is between the outer fork surface and the fairing.
I will post a photo when I get home
kemes
Post by kemes »
A pic of the new routes + riser set would be nice..
2000' VTR1000 Firestrom
A throttle cable thread from last year ? viewtopic.php?f=30&t=42222
felix barrao
Post by felix barrao »
MacV2 wrote: Tue Feb 12, 2019 8:53 am
+1
I had to do that when installed the SLS handlebar
I fitted early blade cables on Lloydies recommendation and they seem fine on my fighter
Flatline
Post by Flatline »
Thanks to all :plainsmile
