Dogbone wanted
Moderator: VTRDark
KermitLeFrog
Dogbone wanted
Post by KermitLeFrog »
My dogbone looks good but the needle bearings were on the way out. Getting a bit notchy. I have new bearings and seals and the collars (pins) look and feel good. But... Can I get the old needle bearings out, can I feck.
Soooo. Does anyone have a dogbone lying about, without bearings and seals? Before I speak to David Silver.
Re: Dogbone wanted
Get a bearing puller set, or dremel it out.
Re: Dogbone wanted
I have one Kermi.
I'll swap it for the one you have...
PM on way...
KermitLeFrog
Re: Dogbone wanted
Dogbone is fine but the bearing is breaking up and not moving. ImageImage
Sent from my LLD-L31 using Tapatalk
Re: Dogbone wanted
Seen worse... :lol: :lol:
KermitLeFrog
Re: Dogbone wanted
Dogbone arrived today. Many thanks Mac.
Re: Dogbone wanted
KermitLeFrog wrote: Mon Dec 17, 2018 4:27 pm Dogbone arrived today. Many thanks Mac.
Re: Dogbone wanted
The returned DB arrived today compleat with funds..Thank you... :thumbup: :thumbup:
When I can be arsed I'll get out into the MacCave & whip them bearings out...
KermitLeFrog
Re: Dogbone wanted
Bearings and seals fitted. Now ready to assemble the final part of the linkage. Thanks once again Mac.
Re: Dogbone wanted
KermitLeFrog wrote: Wed Dec 19, 2018 1:54 pm Bearings and seals fitted. Now ready to assemble the final part of the linkage. Thanks once again Mac.
KermitLeFrog
Re: Dogbone wanted
No wonder I couldn't get the old bearings out. The new ones took a hell of a push to get in. Almost reached for an extension thingy on my 4" vice. I can see why Honda specify a special tool.
Re: Dogbone wanted
KermitLeFrog wrote: Wed Dec 19, 2018 4:55 pm No wonder I couldn't get the old bearings out. The new ones took a hell of a push to get in. Almost reached for an extension thingy on my 4" vice. I can see why Honda specify a special tool.
Eh ???
Normaly just squeez them in easy... Freezer for a min of 24hrs & keep the dog bone somewere warm, bit of greese to help the sliding, they normaly go in fairly easy...
