Page 1 of 6
Polishing the Turd
Posted: Fri May 04, 2018 8:44 pm
by motojohn
Re: Polishing the Turd
Posted: Fri May 04, 2018 8:50 pm
by motojohn
started on the brakes the were proper nasty , i have never seen thick snot inside a caliper before
quick go in the dishwasher wile the wife was out cleaned them a treat
Posted: Fri May 04, 2018 9:01 pm
by Kev L
They always find out!
Posted: Fri May 04, 2018 9:09 pm
by VTRDark
Dishwasher
love it, and you have used the wifes jelly mould by the looks of it.
As for the fork cap. Lower the compression and rebound so it's out the way and put a 6pt socket on there. An open ended or 12pt ring spanner is always going to end up doing that as they are really soft. You may get away with filing those nibs off the angles there. Are you intending on removing the cartrige or simply tipping out the oil for a refresh. My callipers where as bad as that the first time I stripped them down. Great job getting that bolt out and re-tapping
Posted: Fri May 04, 2018 9:46 pm
by StormyRob
Good work mate! Those pistons look to have cleaned up nicely.
Posted: Fri May 04, 2018 9:50 pm
by Duffy1964
Love the use of the dishwasher
Top man
Posted: Sat May 05, 2018 8:33 am
by fabiostar
Epic caliper snot i have to say
Posted: Mon May 07, 2018 11:40 am
by mags@port
Did My Vespa engine cases in the dishwasher also, removed all the hard crud and came our a treat. Wife was also out for the day, never suspected anything apart from noticing I must have used it as the dishwasher as all this clean dishes were put away
. Anyway there is a set of link pipes on flebay just now.
https://www.ebay.co.uk/itm/HONDA-VTR100 ... SwFm5a6YdM
Re: pulling the pipes
Posted: Thu May 10, 2018 7:37 pm
by motojohn
so now to start removing the exhaust
[/img]
you have to wonder why you would make a stainless exhaust clamp and put a ferrous bolt that turns to cheese as soon as it gets wet so i had to cut them off .
but a quick clean with the sander to give it a satin finish in prelude to a mirror polishing
the swing arm is also getting a polish or maybe swapped for a vfr800 one as i have one kicking arround
Re: working the seat
Posted: Sun May 13, 2018 8:40 am
by motojohn
Re: the carbons here
Posted: Sun May 13, 2018 8:48 am
by motojohn
the mudguard arrived
started removing the repair it was well done but i did not like the damaged mesh
so rather than repair it from the back i did a carbon plate from the front in plain site
Re: made a start on the tank
Posted: Sun May 13, 2018 8:57 am
by motojohn
Posted: Sun May 13, 2018 4:05 pm
by VTRDark
Your making some good progress there. The Ducati rear end will look so cool
Posted: Sun May 13, 2018 4:06 pm
by mik_str
Nice work. Are you looking at using the Duc subframe or adapting the VTR unit to accept the Duc cowling? Inquiring minds want to know, lol
Posted: Sun May 13, 2018 4:21 pm
by AMCQ46
you are getting stuck into that bike now .. looking forwards to seeing the end result
