Some observations of the Blue Rinse Special
TaxiDriver
Post by TaxiDriver »
Hi folks,gave it a good clean today and observed these items......
Looks like a different MC has been fitted to match the calipers.
Sure does have a Hagon......
Looks real HOT in blue...........
Also has a speedo healer fitted,so presume that means altered gearing?!
Exhaust seems to be one piece,don't know if intentional.........
JEEZO!! how do I get the pics to show as typed?
Re: Some observations of the Blue Rinse Special
if the clutch side still has a plastic pot, then this is likely to be a CBR600 master, which is a good match.
also looking at the fork preload adjusters, being almost all the way out suggests that the std springs have also been replaced which is also a good mod
to make the pictures work, copy the imager link and then look on the command ribbon above the box you are tying the message into.... on the top row beside the [*] there is a picture icon. click on that and it will give you (img][/img). you put the link in the middle of that
TaxiDriver
AMCQ46 wrote: Sat Jan 06, 2018 8:47 pm to make the pictures work, copy the imager link and then look on the command ribbon above the box you are tying the message into.... on the top row beside the [*] there is a picture icon. click on that and it will give you (img][/img). you put the link in the middle of that
All good as usual,thanks for that info.
It may take some time to actualy manage those instructions so I would be grateful if you could envelop them for me until I have it right... :roll:
TaxiDriver wrote: Sat Jan 06, 2018 9:17 pm
It may take some time to actualy manage those instructions so I would be grateful if you could envelop them for me until I have it right... :crazy:
On imgur when you download a pic it gives you an opption panel you need to click the right one IIRC the BBcode one it has this above it...BBCode (message boards & forums) It has a blue copy button. Left click on that. then just paste it in your text. There is no need for the img boxes. it will do that for you.
see here...viewtopic.php?f=10&t=41262
TaxiDriver
MacV2 wrote: Sat Jan 06, 2018 9:27 pm
Yea man I get that....I just aint fit atm to actualy do it.....
So can you pls do it for me...... :beer:
Here you go....
