blowing main fuse at solinoid
minty
Post by minty »
Hi all
I am having trouble with main fuse blowing at solenoid.
Battery was charged when the oil was being changed and new filter put on when I put the battery back in and went to connect it up the fuse blew.I left battery connected put in a new fuse but when I went to put the connector back on it just shorted straight away. what is puzzling me is no ignition on. its a direct short but looking at the loom I cant see anything stripped back to the frame to cause this
anyone any ideas
thanks MINTY
Re: blowing main fuse at solinoid
Have you got the battery the right way round?
tony.mon wrote: Wed Oct 11, 2017 4:38 pm Have you got the battery the right way round?
Been there done that... :lol:
The cables just about reach the struggle to get them on SHOULD have told me something was wrong...POP !
Ahhh quick change the fuse swap the batt round. No one will ever know...DOH!
StormyRob
Post by StormyRob »
When some idiot put the battery in the wrong way round in my bike I had the main fuse go over and over. Turned out I just needed to change the reg rec and problem was solved as it was fried.
