Top front engine mount bolt.
Moderator: VTRDark
So if anyone happens to have a genuine top front engine mount bolt c/w the spacer for the left hand side, the nut & adjuster doh dah they want to part with Mr Vanstub would be most gratefull...
Re: Top front engine mount bolt.
To avoid confusion, it's about 340mm long-
Confused of Kemsing
tony.mon wrote:To avoid confusion, it's about 340mm long-
Confused of Kemsing
:lol:
popkat
Post by popkat »
Looks cheap enough for new parts, if the spacer is part 19 then it could take a few weeks but the bolt looks to be in stock. you could make or get a spacer made if you know the size for not much.
https://us.fowlersparts.co.uk/parts/510 ... frame-body
popkat wrote:Looks cheap enough for new parts, if the spacer is part 19 then it could take a few weeks but the bolt looks to be in stock. you could make or get a spacer made if you know the size for not much.
Cheers Poppers.. :thumbup:
We used a wheel spacer ground down to fit nice & tight, a gentle hammering with a small hammer, nice snug fit.
vanstub
Post by vanstub »
and i also need the 20x77mm adjuster as after plusgas and a bit of heat my 1 snapped in old frame :Mad3:
Life's too short for plain biscuits :thumbup:
vanstub wrote:and i also need the 20x77mm adjuster as after plusgas and a bit of heat my 1 snapped in old frame :Mad3:
Tks... Gorilla mit's strikes again... :lol:
