Which calipers and pfm discs
Which calipers can be used with pfm cast discs?
- agentpineapple
Re: Which calipers and pfm discs
iirc kev uses ptm discs, not sure they are cast tho, he uses sp/blade cslipers
Discs Standard size, over size, narrow track ?? calipers depends which PFM discs you have
OR if you mean Pads then use NON Sintered type
320mm diameter, 25mm width
If they are Narrow track then you may need the PFM calipers. measure the pad area of one of the pads in your current calipers. if they're 25mm then you could get some adaptors made to fit with the discs.
A picture would be helpful
cybercarl wrote:![]()
![idea :idea:](./images/smilies/idea.gif)
so, just to be clear, you are saying the adaptors need to resemble the A-frame?cybercarl wrote:![]()
![Big Grin :biggrin](./images/smilies/biggrin.gif)
- agentpineapple
I will be on the look out for some pfm cast disc outer sections in the near future, as mine are slightly worn, they aren't mega money, I think £90 each side. as malc says, if they're narrow track, nissin caliper won't work as well because of the lesser contact patch.YETI wrote:AP would suit those but not seen any around for a while .
YETI ..
