Info on making my own exhausts ...
Stepkevh
Post by Stepkevh »
As a tig-welder i would be crazy not to try and make my own exhausts in stainless steel.
But as i lack knowledge around that subject, maybe some clever guy's here have some info.
Are there certain things to keep in mind ?
Does the volume need to be the same as the original ones ?
And something that i always questioned, purely talking about "straight-through" pipes here,
how does it come that if you take 2 different brands with same model they make a different sound ?
More ... less damping-wool ?
Love the sound of Microns, 2 Brothers, .... just that deeeeep lovely note that gives you the shivers :lol:
~ Imagination is only limited by your mind ~
mik_str
Re: Info on making my own exhausts ...
Post by mik_str »
You may want to try modding a stock header first, as I recall reading it was pretty good, up to the collector that is, which is supposed to be undersize for optimal performance. Personally, I would try making a larger collector as a first step.
As for the header diameter, going bigger will improve top at the detriment of bottom and going smaller will have the adverse effect.
Good luck and keep us posted :)
Stock vs yoshi big bore .
Just remember Honda,HRC ,yoshi,moriwaki,akrapovic,arrow, pumped millions into exhaust development .
My advice would be to reproduce one of theirs .
The stock headers only need the welds cleaning up in the very first bit where it meets the head .
Stepkevh
Post by Stepkevh »
I was actually talking about making my own cans not the headers :)
Polished mine a bit already :lol:
-Floris-
Post by -Floris- »
It all depends on how loud you want them to be or how you want them to look like. 8)
It's sad that, in our blindness we gather thorns for flowers
Stepkevh wrote:I was actually talking about making my own cans not the headers :)
Good job with the polishing on the exhaust headers :clap:
As I understand it, changing the total length of an exhaust system will change the way the big runs, and may mean carb settings, even jet changes will be needed,
Id go with 43mm link pipes and 60mm internal can diameter . Be loud as fook tho ha ha
-Floris-
Post by -Floris- »
But at first, what kind of shape do you have in mind? I think it can be hard to say something useful unless this is known.
Stepkevh
Post by Stepkevh »
-Floris- wrote:But at first, what kind of shape do you have in mind? I think it can be hard to say something useful unless this is known.
Does the shape affect the sound it makes ?
Definitly not round, maybe oval or even triangular in some way :)
Length is a factor - stubbies are very noisy.
Why not find a damaged aftermarket can, dismantle and see if you can duplicate it with some reverse engineering.
B-29 > TU-4 reverse engineering http://b-29s-over-korea.com/shortstorie ... nclone.htm
Bigger internal diameter 60mm with a long 500mm can will sound very deep but not bark if you know what I mean .
The quill cans have a 55 or 57mm internal and 470mm long and by far the they sound deep and dirty .
Ask anyone who has them without baffles
Stepkevh
Post by Stepkevh »
Wicky wrote:Length is a factor - stubbies are very noisy.
That was actually my first idea with my own cans... the one you see on the pic up here.
These cans are damaged, i already changed the outer rings with 15 mm / 0,8 mm Stainless Steel and new SS rivets.
The center bracket is also changed by myself with again SS 30 mm / 0,8 mm.
Just did that to have something when i can start driving it, thats why i can't use those to do some reverse engineering
The sound they make is wow :)
Your link isn't working :)
Stepkevh
Post by Stepkevh »
lloydie wrote:Bigger internal diameter 60mm with a long 500mm can will sound very deep but not bark if you know what I mean .
Still dont get the use of bigger internal diameter while the headers are only 42 mm.
My ovals are 42 or 45 internal and only 440 mm long, nice deep sound as well :)
Stepkevh
Post by Stepkevh »
lloydie wrote:Image
As i look at the picture, i assume the left is the Yoshi diameter 50 mm or something ? 8O :lol:
52mm-55mm :-) yoshi on the left
